If the link won't work then you can go to www.smokemup.com and look for the auto math tab at the top of the page. Then scroll down for rear gear ratio.
BTW: I used a 27 inch tire and 3100 RPM> The numbers shown are the program default.
thanx for your help...but...
that table dosnt help because i dont know tire height, nor dose it take into consideration my tray ratio...
The program said that you needed the MPH and RPM information from your 1 to 1 transmission ratio. That would be 4th gear if you have a 4 speed.
The correct tire sizes for a '79 are Standard 225-70-15 with a stated diameter of 27.2 inches, optional was the 255-60-15 with a stated diameter of 27.1 inches. You could go out to the garage and measure your actual tire diameter.
