What is this for? "Aeroquip hydraulic mandrel"
What is this thing for? I've never made SS braided line before, but can't imagine why you'd need this thing... if I'm imagining its use correctly, it can only be used for straight hose ends? Anyone ever used one?
http://cgi.ebay.com/ebaymotors/ws/eB...e=STRK:MEWA:IT
-Chris
-Chris
-Chris
-Chris
Ah, I read about an older style in Carroll Smith's Fasteners&Plumbing book (aka Screw to Win) Didn't remember anything about a tool being needed though!
Bob, sounds like you are thinking of solid metal line. Aeroquip makes stainless steel brain-sheathed rubber hose.
Thanks MrForce
-Chris
Thanks MrForce
-Chris
It's for a "current" reusable steel fitting. AQP hose for power steering, brakes, high pressure gauge lines, etc. It's a low cost line with NO HEX on the nipple. Not a very popular line. You thread the socket onto the hose, thread the tool onto the nipple assembly to give something to grap onto, insert the mandrel into the tube and start turning. The mandrel expands the tube slightly to prevent the nipple from bitting into the end of the hose. The threads bottom out against the face of the nipple and prevent it from turning independent of the nut.
Yes, I used to work for Aeroquip.
