Safety harness?
Old Nov 17, 2004 | 11:45 PM
soccer794's Avatar
soccer794
Default Safety harness?
The C3s seat belts simply will not do. Having just a lap belt is just not going to cut it for me, I need some sort of a shoulder belt. At first I was thinking of trying to find a kit to just add a normal shoulder belt, but then a friend of mine suggested a 4 or 5 point safety harness that bolts into the chassis. This caught my attention and I did a little investigating but not too much. I found 5 point harnesses on Jegs.com for around $100. Any opinions on if this would be a good idea? Also if anyone knows of any good companies or anywhere to get good prices that would be great.
Old Nov 17, 2004 | 11:50 PM
Bryan8412_2's Avatar
Bryan8412_2
I'm putting sparco seats and 3 pt bolt in harnesses in. I saw someone else on the forum with this type setup where they removed the stock shoulder belt "feeder" and the resulting threaded hole was used for the back pt. In the mass confusion of the frame off I never checked to see if the bolts threaded in right I guess tommorow I could go check lol. Hopefully it will work or I'll mount it somewhere else I guess. He also noted it was out of the way and did not interfere with his "trunk"
Bry
Corz's Avatar
Corz
Cruise-In IV Veteran
my 69 has shoulder belts.. from the factory..
they're available if you hunt..
or you could take some 4th gen Camaro seat belts
Old Nov 17, 2004 | 11:58 PM
soccer794's Avatar
soccer794
My 71 did not come stock with shoulder belts...what all is required if I decide to go that route?
Old Nov 18, 2004 | 01:11 AM
Corz's Avatar
Corz
it should have.. it was standard equiptment halfway through the 69 model year.
Old Nov 18, 2004 | 04:12 AM
aharte's Avatar
aharte
Not for convertibles.
Old Nov 18, 2004 | 07:11 AM
Paul L's Avatar
Paul L
I would imagine that you could adapt a C2 (1966-67) shoulder belt to your car. BTW I shared your thoughts about just having a lap belt so I installed this set last spring.
To Safety harness?
