Anyone ever have to cut the top of the fenders off to get at a rusty lower windshield frame?
How hard was it to replace and blend back in using fiberglass(the fender)
Does this weaken the fiberglass? I'm worried that if I do this the panel might crack along the repair after I paint it.
Why not remove the front clip? Then you can just bond it back in place, less work in the long run. When you do a thorough job on the fiberglass it won't be any weaker than the original but why would you want to go through all that.
From: WAY DEEP INSIDE AMERICO,YES YOU LIVE HERE TO!! TX
I have a book with step by step instuctions
on how to do that, it's pretty easy. I got it
from MID-AMERICA part # 600.--029 in the
books section. the book is called, corvette
water leaks, and wind noise solutions, they
show a red 80/82 on the cover,front end only
