Cheap Aluminum heads?
Old Nov 19, 2004 | 11:38 PM
ZD75blue's Avatar
ZD75blue
Default Cheap Aluminum heads?
Hey guys...
I would like to find a set of cheap aluminum heads that work with the TPI injection (I'm pretty sure TPI is on the same bolt pattern as the vortecs?)
Weight savings! Higher compression ratio with lower octane...
I need some idea's... Buy a parts car that has everything needed to make the swap?
Old Nov 19, 2004 | 11:46 PM
75 Stingray!'s Avatar
75 Stingray!
Originally Posted by ZD75blue
Hey guys...
The only production aluminum heads you can use with TPI are the ones off a L98 Corvette.
Vortec heads are not aluminum and are raised port, I think edelbrock makes a TPI base intake for raised runners but the bolt pattern is different.
Old Nov 20, 2004 | 12:04 AM
ZD75blue's Avatar
ZD75blue
Gotcha...
Knew the vortecs were cast... was pondering the bolt pattern for the TPI.
More reading needed me thinks.
Old Nov 20, 2004 | 07:19 AM
Steve's74's Avatar
Steve's74
...cheap aluminum heads...
Isn't that an oxymoron?
Steve
Old Nov 20, 2004 | 07:29 AM
Gordonm's Avatar
Gordonm
The L98 is not a bad head for the TPI system. A little port work and they flow decent. By the time you rework and port them they are no longer cheap though.
Old Nov 20, 2004 | 09:10 AM
ZD75blue's Avatar
ZD75blue
I keep hearing that...
I doubt, I can find a wrecked vette... with a decent engine, of that vintage... cheaply!
I'm fighting the urge to upgrade my 882 (76cc heads ) in hopes of switching to a set that have a good bit more potential. The Vortecs are great heads... out of my budget for the moment, requiring rockers, and a new intake to run!
Thanks for the heads up
Old Nov 20, 2004 | 09:25 AM
page62's Avatar
page62
I just got a set of these from Summit Racing...
They have similar specs to the "fuelie" heads from the late '60s, but also have heart-shaped chambers similar to Vortecs (the photo doesn't show this). 67cc chambers, 2.02/1.60 valves, 165cc intake runners. An excellent bargain at only $650/pair!!!
Go to Summit Racing and search SUM-152123. They're actually made by Dart and are similar Iron Eagle Street/Strip heads, but with bigger valves and smaller chambers
BTW: TPI should bolt up to these. L98 heads used a standard -- not Vortec -- intake bolt pattern.
Old Nov 20, 2004 | 09:26 AM
page62's Avatar
page62
BTW: TPI should bolt up to these. L98 heads used a standard -- not Vortec -- bolt pattern.
Old Nov 20, 2004 | 09:29 AM
Fevre's Avatar
Fevre
TPI intakes do not have the same bolt pattern as the vortecs, they have the same bolt as our stock heads except the 2 inner bolts on each side are angled more upright but you can grind the intake to allow use of all older style bolt patterns.
Old Nov 20, 2004 | 09:39 AM
ZD75blue's Avatar
ZD75blue
Cool!
650 a set... using the same intake I have now... Vortecs or aluminum heads. Let me think, uh... aluminum!
Old Nov 20, 2004 | 09:45 AM
Fevre's Avatar
Fevre
Cool!
The heads referenced are iron not alum.
Cylinder Head, Cast Iron, Natural, 67cc, Chevy, Small Block
Old Nov 20, 2004 | 10:01 AM
ZD75blue's Avatar
ZD75blue
Well...
There goes my fun.
Saw what I wanted em to be I guess... (that and had not taken the time to run the part number on summit...)
Old Nov 20, 2004 | 10:09 AM
page62's Avatar
page62
Oops, sorry. Forgot to mention that. What's the problem with cast iron?
Old Nov 20, 2004 | 10:31 AM
mandm1200's Avatar
mandm1200
The Summit heads use centerbolt valve covers. You'll need to purchase them as well. They compare these to the old GM double humps, not bad, but not as good as the Vortec's.
Changing the heads should be an improvement, but in my opinion just changing them is not going to make a whopping difference. Buy what you can afford now and keep saving up until you get the intake and cam. By changing all three you will see and feel the difference.
Old Nov 20, 2004 | 11:01 AM
Joebio's Avatar
Joebio
I am sure this is a mistake on their site but if you go to summit, http://store.summitracing.com/defaul...4922130+305337
They have the aluminum vortec heads for $259, I say hey give it a shot and see what happens.
Old Nov 20, 2004 | 11:06 AM
cardo0's Avatar
cardo0
From: Las Vegas - Just stop perpetuating myths please.
Default Awsome price.
Great price and only negative feature is lack of heated crossover for a stock replacement head. But then if someone is using FI then its not an issue. cardo0
Old Nov 20, 2004 | 11:10 AM
mandm1200's Avatar
mandm1200
That's a misprint. The Vortec is cast iron. I believe the more expesive head has the springs changed to accomadate higher lift.
To Cheap Aluminum heads?
Old Nov 20, 2004 | 12:07 PM
PatsLs1vette's Avatar
PatsLs1vette
Im using world products sportsman 2 heads on my tpi.(cast iron)
Old Nov 20, 2004 | 12:21 PM
75 Stingray!
Misprint
Cylinder Head, Aluminum, Natural, 64cc, Chevy, Small Block, Each
These cast iron Vortec cylinder heads will fit 1958 and later small block Chevy engines, and offer a 20 to 40 HP increase over earlier cast iron small block heads.
Cylinder Head Material Cast iron
Old Nov 20, 2004 | 01:02 PM
Fevre's Avatar
Fevre
I agree the l98 alum vette heads are not a bad deal, they use them on the ZZ4 crates. If you plan to go over 400 hp then I would either buy better heads to start or save and buy later.
