carbs
Old Nov 22, 2004 | 11:51 AM
revRup's Avatar
revRup
Cruising
Default carbs
what carburators are all of you using on your 350ci engines? i have the stock quadrejunk mine now but am thinking of upgrading to somehting bigger and better. what do u all think?
Old Nov 22, 2004 | 11:55 AM
GrandSportC3's Avatar
GrandSportC3
Cruise-In IV-V-VI-VII-VIII Veteran
St. Jude Donor '03, '06, '17
Holley mech. secondaries carb... Depending on your engine - I'd use a 650 or 750 Holley mech. secondaries double pumper...
Well - if you are not concerned about performance - go with the Holley 750 vacuum secondaries...
Old Nov 22, 2004 | 11:59 AM
nastee383's Avatar
nastee383
If you have a stock or moderately modified motor you already have a good carb. There isn't anything better if it's tuned right.
Old Nov 22, 2004 | 12:23 PM
an81shark's Avatar
an81shark
barry grant
Old Nov 22, 2004 | 12:34 PM
73sbvert's Avatar
73sbvert
Crackin' on...
St. Jude Donor '09
Small block tri-power! (Fenton/Roch.)
Old Nov 22, 2004 | 12:46 PM
viperjesse's Avatar
viperjesse
Holley 600 or 650 double pump mechanical secondaries. You'll get a nice crisp throttle with low end torque and no bog. When the mechanical secondaries come in you'll have the rpm's to deal with it.
Old Nov 22, 2004 | 01:24 PM
SteveG75's Avatar
SteveG75
Is your engine modified? The Holley/BG's can be easier to tune but a good Q-Jet will easily feed a modified motor, deliver good driveability and mileage. People have run 12's with Q-jets and I am feeding a 400 horse motor with one.
Swapping the carb with no other mods will do very little if the original was in good shape. Obviously, if your carb is in bad shape then any carb will be an improvement.
Old Nov 22, 2004 | 01:38 PM
lars's Avatar
lars
If you intend to retain your stock intake manifold you need to stay with a Q-Jet. Holley and BG use square bore patterns and will not bolt up to the stock intake.
Old Nov 22, 2004 | 03:22 PM
comp's Avatar
comp
he know's
Old Nov 22, 2004 | 04:07 PM
stingry's Avatar
stingry
St. Jude Donor '05-'06
I am using a QJET and I am very happy with it!
Old Nov 22, 2004 | 04:12 PM
Carl Granquist's Avatar
Carl Granquist
Stock Q-Jet with my 350CID/270HP '71. Seems adequate but it idles a little fast, which is why I read all of these "carb" threads.
Old Nov 22, 2004 | 04:48 PM
page62's Avatar
page62
The carb is only one piece of the puzzle. You cannot simply slap a fancy new carb on there and expect a performance improvement. Think of the whole system instead -- in this case, it would be carb, intake, headers, and exhaust.
Tell us what your car currently has in terms of all of these (plus the engine) and we can provide ideas on the best place to start...and where to go from there
To carbs
