c3 frames
Old Nov 22, 2004 | 05:37 PM
john21's Avatar
john21
3rd Gear
Default c3 frames
hi can anybody tell me the diffrences in c3 frames
how compatable are thay i need a 1969 4 speed frame
Old Nov 22, 2004 | 05:41 PM
i885744's Avatar
i885744
4 speed frame = automatic frame with a small tab welded on to it for the clutch linkage and a welded in non-removable transmission crossmember. As far as years are concerned, I'd wait for someone who knows more than I to post about this, but I believe the frames are the same for all the c3's. Certainly 68-77 must be the same.
Old Nov 22, 2004 | 05:43 PM
StingrayDK's Avatar
StingrayDK
69-72 should be the same.
Auto trans = removable crossmember.
Manual trans = fixed crossmember.
Old Nov 22, 2004 | 05:52 PM
matchframe's Avatar
matchframe
If you do find an automatic frame you can get the Clutch Pivot Bracket from Zip to weld on the frame. Zip's part # is CL-205 for the bracket.
www.bigdogvettes.com
Old Nov 22, 2004 | 05:57 PM
Chuck Gongloff's Avatar
Chuck Gongloff
Active Streak: 90 Days
You'll find differences in the rear with a rubber bumper shark frame as compared to a 69 frame. Same deal up front with the frame horns.
There are also various gussets that are different. I'd look for a correct frame. Chuck
Old Nov 22, 2004 | 08:54 PM
Paul Borowski's Avatar
Paul Borowski
Cruise-In VI Veteran
St. Jude Donor '08-'09-'10-'11-'12
As far as I can physically tell, '68-'74 are the same. The '75 & on up is where the back end of the frame changed drastically for the "hydraulic bumper shocks", which '74 did NOT have. My '68s & my '74 look identical back there, except a '74's rear bumper absorbed shock through a "sliding" mechanism that was on each side of the rear of the frame. This you would remove for use on a pre-'74 car. Now there may be an extra hole or two here and there for this "sliding mechanism", but it looks the same as my '68s. '68 frames also did not have the "angular" gussets between the main rear lower perimeter crossmember and the doglegs(kick-ups)over the trailing arms. This applies to almost all '68 frames. Very late '68s(last couple thousand)DID HAVE these angular "gussets".
To c3 frames
