old vin tag/new windshield post?
http://cgi.ebay.ca/ws/eBayISAPI.dll?...spagename=WDVW
If you NEED to replace that section of post, then this may be an alternative:
Cut the section of post open (once removed) and grind the
back side of the rivets to remove them without affecting the
part that is seen. Then, re-attach the VIN tag with rivet heads
with some epoxy - or good adhesive of your choice.
Of course, legally, you should proceed by contacting your DMV
and seeing what the law says in your state.
Some folks say that the frame stamp is the true VIN number for the car, but everyone looks at the WS post tag for ID.
You could also make some rosettes with pop rivets and a file .... but the educated eye can tell.
Good Luck
