Frame coating ?
Rick B.
I'd say go for a quart.
Here is a quote from their website:
"All estimates below are made using one coat on the area being treated; however, we recommend two coats in most applications.
POR-15 application on non porous surfaces (most metals):
Approximate coverage:
* Pint = 50 sq. ft.
* Quart = 96 sq. ft.
* Gallon = 350 sq. ft.
For porous surfaces like wood & concrete, coverage will be about 20% less.
When painting on metal surfaces, we recommend at least 20oz. of Metal Ready for every quart of paint or coating you use"
Rick B.
http://www.itkillsrust.com/
I would opt for the "six pack" of 1/2 pints. You can also mix/match
colors in the six pack.
I used silver POR, since I was top-coating with black.
The silver gives a good contract, so you don't miss any
areas with the top coat or go too thin.
silver POR - let get tacky - 'dust coat' with Krylon semi-flat
black while tacky - let cure overnight - top coat fully.
It's a couple days work (lots of cleaning and waiting).
Make sure you get all the old paint off ... and clean metal should
be etched for good adhesion. Home Depot has a product similar
to Metal Ready (Must for Rust). It is Phosphoric acid ... etches
and
treats bare steel for coating. Naval Jelly works good too.
If you let it dry on your skin....it is there for about a week!!
I used Rust-olium's Satin balck for the topcoat.
73Gator - Great looking rolling chassis. I hope mine comes out half that good!
Rick B.
