Engine Problems, Please Help!!!!!
Old Nov 27, 2004 | 11:41 AM
djcwardog's Avatar
djcwardog
Mark,
I checked the resources you listed. Good stuff! I wonder if I can gin up a sensor that will give idle readings even if I don't want to weld a bung and instead only want to stick it up the tailpipe like they do at the emissions stations... Would make tuneups easy! Thanks!
Old Nov 27, 2004 | 11:49 AM
LFZ's Avatar
LFZ
Interesting..i know a guy with a fastburn 385 and NO hot cam and his car dynoed 308hp at the WHEELS! Yours sounds like its got a timing issue, and potential hp is there..you'll find it.
Old Nov 27, 2004 | 03:26 PM
NotPopz's Avatar
NotPopz
Yep, my throttle is oping 100%...i had my uncle take it for a drive and we then looked at the carb and saw the back bowl was too full so we adjusted that. hopefully tomm i can get the distributor installed and timed and take it for another drive...Hope this michigan weather allows me to.
Old Nov 27, 2004 | 03:34 PM
NotPopz's Avatar
NotPopz
My uncle is also in the process of l;earning the LM-1, so soon i'll be able to have teh AFR taken.
Old Nov 27, 2004 | 11:34 PM
micks69's Avatar
micks69
Originally Posted by BigBlockk
You did check to make sure that the accelerator pedal opens the throttle blades 100% didn't you?
Just a thought.
BigBlockk
Later.....
Old Nov 28, 2004 | 01:45 PM
NotPopz's Avatar
NotPopz
Yep the throttle opens 100%.
Put the new MSD distributor and Coil in today...Set timing to 34 degrees. Took it for a drive...its hard to tell if it is any different because drives are to far between. Next step is the air/fuel ratio. then i'm dynoing it again.
Old Nov 28, 2004 | 08:39 PM
Brettmc's Avatar
Brettmc
Stick an O2 sensor in the collector and read the output with a multimeter. My bbc runs good at around 900 millivolts. Any other method of carb tuning is guesswork. Also, the only time you need a large spread between the primary and secondary jet sizes is if you run a power valve plug in the secondary side. Otherwise, square jetting (or a size or 3 larger) is fine. But I agree with the others, it was prolly the timing gving a low HP number. Get that right and then work on the fuel mixture.
Brett
Brett
