8mm
Old Nov 27, 2004 | 05:29 PM
an81shark's Avatar
an81shark
Default 8mm
was the only wrench in my car. it would be the only wrench i would need to bypass the blown heater hose.
if you haven't checked your hoses in a while, go check em. 2in heater hose gashes aren't pretty
Old Nov 27, 2004 | 05:58 PM
comp's Avatar
comp
thats all it took ?????
Old Nov 27, 2004 | 06:08 PM
an81shark's Avatar
an81shark
to get home. I just ran the hose coming from the intake manifold to teh outlet on the water pump, thus bypassing the blown hose. the clamps were 8mm heads, so thats all i need. also took a quick stop at sears for some coolant.
limped home, then replaced all the old hoses. all is well now.
Old Nov 27, 2004 | 06:10 PM
Nowhere Man's Avatar
Nowhere Man
2015 C2 of Year Finalist
don't you mean 1/4"
Old Nov 27, 2004 | 06:26 PM
greyghost79's Avatar
greyghost79
also, aren't your two heater hoses different sizes? 5/8 and 3/4. mine are. how did you get 3/4 water pump hose to fit 5/8 manifold inlet?
an81shark's Avatar
an81shark
nope it was defiatnly 8mm. the clamps on the hoses on the heater end were 1/4
Old Nov 27, 2004 | 06:27 PM
an81shark's Avatar
an81shark
i've got 3/4 all the way around on mine. it may have been 5/8 before me, but 5/8 don't fit now. i tried once
To 8mm
