idle mixture on 79 Q-Jet
Old Nov 29, 2004 | 12:44 AM
greyghost79's Avatar
greyghost79
Default idle mixture on 79 Q-Jet
how do you gain access to the idle mixture screws on this era of Q-Jet? I know they're sealed but I know there is a way to open 'em up. just don't know how to do it. thanks for the help.
Old Nov 29, 2004 | 06:47 AM
Gary79's Avatar
Gary79
i replaced the 79 quadra on my 79 vette with one from edelbrock, the original is sitting in a box in the garage attic, but from what i remember. the area around the mixture screws looked like it was ripped opened by some sort of tool. i mentioned this to a mechanic friend and he said that there was a tool made that broke thru the pot metal covering the mixture screws. i have never seen this tool, i would guess that you could carefully drill the pot metal away from the screw openings.
Old Nov 29, 2004 | 09:09 AM
lars's Avatar
lars
If the steel caps are still in place, you pull the carb off, flip it upside-down, and break out the casting between the dotted marks under the mixture screws. This will allow the caps to be knocked out. For a cleaner removal, you can drill the steel caps and pry them out without breaking out the bottom of the throttle plate casting. The screws then take a special tool to adjust them (available from NAPA).
To idle mixture on 79 Q-Jet
By Michael S. Palmer | 2026-06-03 09:39:05
