info on 71 conv.
Old Nov 29, 2004 | 11:43 AM
c.s.'s Avatar
c.s.
2nd Gear
Default info on 71 conv.
First off, thanks for your time. Need info and advice on a 71 convertible that I'm looking to purchase from a private party.Yes I am new to the "vette world" and have always been a fan of this style. The car has a 350/270hp,ps,mb,no air with 80,000 miles and is in exc shape,all original with new paint. Car has all original parts and what is new has been replaced with all original items. Paint is also original color. Soft top in exc condition. Same with interior. All numbers match. Car is in exc condition with hardly any flaws. Very well taken care of and only driven a few hundred miles a year. Car has also won a few awards. Asking price is $25,000. What is this car worth and what should I pay? Is there a lot of miles on this car for that price and if I drive it more than a few hundred miles a year and near 100,000 miles will it still hold its value if kept in the same shape lets say 5-10 years down the road? Any info and advice would be much appreciated.
Old Nov 29, 2004 | 12:05 PM
gdh's Avatar
gdh
check the frame and windshield for rust if none, then $20 - 25k for an LT-1 vert. is not too expensive if it is in as good a shape as you say. Call a local corvette club to have them recommend a mechanic to over the vette to find things that you may not see.
Old Nov 29, 2004 | 12:22 PM
zwede's Avatar
zwede
But this one is a base engine car so I think $25k is too much even if it checks out. If the mechanicals are in excellent shape as well as the interior and paint I can see upper teens.
Be sure to have someone who knows C3's do a thurough check. These cars have a few unique areas that need close checking such as the frame just in front of the rear wheels rusts out and the front crossmember where the lower A-arms attach can crack. Also have to inspect the rear suspension, wheels bearings, stub axles, strut rods etc. Rebuilding rear suspensions on these cars gets expensive if you have the work done.
Old Nov 29, 2004 | 12:23 PM
early shark's Avatar
early shark
cs:
I'll give you my opinion, if it's any help to you. I have owned several 1970 thru 1972 Corvettes. Including 3 '70 LS-5's, 1 '71 LS-5, 1 '71 LS-6, and 2 '72 ZQ3's.
The '70 thru '72 'vettes are the refined version of the "early shark era" cars. I believe they will continue to appreciate a lot in the continuing years. Currently the convertible model holds an edge over the coupe as far as value goes, however I believe the LT-1 & LS-5 options will far outdistance the ZQ3 engine in upcoming years as far as increased value will go.
The price of the car you are looking at, seems reasonable for what you are presenting the condition to be. I believe for a few thousand more, you could get a much more desireable optioned model that would hold it's value much better, as well as increase significantly in value in future years.
I would think hard, on what it is about these sharks, that attracts you to them, as you can see I am hooked on them. Find what particular options really get you excited and persue a car that has them. I don't believe you can ever pay too much, only too soon. As time goes by, it will seem like a bargain!
Old Nov 29, 2004 | 12:35 PM
Nifty 71's Avatar
Nifty 71
Assumjing no frame rust, good paint and good interior, this is a good price for a LT1 convertible. With a little help anything else can be repaired at a resonable cost.
Old Nov 29, 2004 | 01:11 PM
markdtn's Avatar
markdtn
As long as the frame, birdcage, and trailing arms aren't rusty, it sounds reasonable. I agree that the BB cars will probably appreciate faster, but I think any chrome bumper vert will continue to appreciate if kept up. My .02
Old Nov 29, 2004 | 03:29 PM
71coupe's Avatar
71coupe
I wouldn't go over 19,000. if it had factory a/c, pb & pw, they may get the 25k. What color is the body & interior (& top)?
Old Nov 29, 2004 | 03:50 PM
Carl Granquist's Avatar
Carl Granquist
I paid slightly over 20k for my '71 coupe which is also a 350cid/270hp last spring. It is my first Corvette but I spent a lot of time (years) looking around and it appraised over my purchase price. It's in very good shape overall and for me anyway it's a "keeper." I do wish it had a high performance engine, but understand that Chevrolet only made so many and the relatively few that are out there for sale AND that are in good shape really command the higher price! Sometimes you just have to go for it and enjoy, or at least that's what finally motivated me.
Old Nov 29, 2004 | 08:55 PM
BUGGSY1970's Avatar
BUGGSY1970
Hey guys this is not an LT-1. In 71 the base model was a 350 270 hp engine. The LT-1 I believe was a 350 HP engine. This car is a lowly optioned car and as such $25K is way too much. Look to take this car home for $18K or less if it checks out mechanically and frame wise. A fully restored NCRS award winner would not be worth $25K with those options.
Old Nov 29, 2004 | 09:51 PM
FormerPacifist's Avatar
FormerPacifist
I thought that was a L-48 engine.
Old Nov 29, 2004 | 09:57 PM
markdtn's Avatar
markdtn
Don't know where your numbers come from, but a freshly restored no-option SB bumper vert will bring about $30k nowadays.
Old Nov 30, 2004 | 12:39 AM
standup's Avatar
standup
Originally Posted by early shark
cs:
.....I have owned several 1970 thru 1972 Corvettes. Including 3 '70 LS-5's, 1 '71 LS-5, 1 '71 LS-6, and 2 '72 ZQ3's.......
What is a ZQ3 ??????
Old Nov 30, 2004 | 03:24 AM
standup's Avatar
standup
Originally Posted by c.s.
......Car has all original parts and what is new has been replaced with all original items. Paint is also original color. Soft top in exc condition. Same with interior. All numbers match.......What is this car worth and what should I pay?........
You're definitely on the right track buying a convertible
But based on your description, I don't think this Vette is worth more than 18k without pics and trim codes, block casting numbers/date, engine suffix codes, head casting numbers , etc. For 25k I'd expect all this and some documentation as well.......post that info here and we'll help you feel better (or maybe worse--depending on the car) about spending all that coin........Besides, we really want to see pics of this Vette
BTW, take a look at 73-75 convertibles.......you miss out on the chrome bumpers, but production is lower
Old Nov 30, 2004 | 03:26 AM
standup's Avatar
standup
......You've just greatly improved the value of my Vert
Old Nov 30, 2004 | 11:38 AM
early shark
standup:
ZQ3 is the RPO code for the standard base engine for the Corvette model, ie: '68 is 300hp/327cid, '69 is 300hp/350cid, '70 is 300hp/350cid, '71 is 270hp/350cid, & '72 is 200hp/350cid.
Old Nov 30, 2004 | 11:40 AM
early shark
FormerPascifist:
RPO code L48 did not come into play for Corvettes until the 1973 model run.
To info on 71 conv.
