input needed for body mount
Old Nov 29, 2004 | 05:34 PM
corv58's Avatar
corv58
Default input needed for body mount
i'm helping a friend mount the body on a '68 roadster. has anyone had any experience with shims,bolt sequence or is it a fairly simple job for a fairly simple guy ? he bought the vette as a real basket case, and is ready to mount the body on now. thx, jim.....
Old Nov 29, 2004 | 06:06 PM
NHvette's Avatar
NHvette
If you do not have a record of how many shims went where ...
then you'll have to start from scratch.
The shims are placed to compensate for irregularities in the
frame and birdcage. I would start with zero shims around.
Snug the bolts down slowly ... and check for door alignment
as you go. Shim appropriately to get the door opening correct.
I am converting the 70 mounts to later (poly) mounts. I hope
that there is less shimming with these. Is your friend using the
stock aluminum mounts for the 68 ??
Old Nov 29, 2004 | 06:19 PM
Chris@VetteFinders's Avatar
Chris@VetteFinders
Platinum Supporting Dealership
Exactly what NHVette said. Make sure you do it right the first time. You can't go back and adjust it later.
__________________
2005 Z51 Coupe
79 coupe
Help us continue to support the forum by visiting VetteFinders.com
www.VetteFinders.com
Your Internet destination for buying and selling Corvettes.
Old Nov 30, 2004 | 11:48 AM
72LS1Vette's Avatar
72LS1Vette
There was a good article in Corvette Enthusiast magazine a few months ago regarding using shims to align various panel gaps. I don't remember the details but I think there was a specific sequence that should be followed to get everything aligned. If you can find the article it might be helpful.
Rick B.
To input needed for body mount
