(Tools) Dial Indicators
Old Nov 29, 2004 | 11:56 PM
matchframe's Avatar
matchframe
Default (Tools) Dial Indicators
I have been shopping for a dial indicator kit. There are several on ebay, but few of them are complete kits with holder, clamps, and magnet. Northern Tools has a couple of kits that are farely reasonably priced. The only dial indicators I have used have been Snap-On which I had borowed once. I want to have them before I start assembling my engine.
What exactly should I look for, and where would be the best place to find them?
Thanks!
www.bigdogvettes.com
Old Nov 30, 2004 | 12:09 AM
CA-Legal-Vette's Avatar
CA-Legal-Vette
I got mine at Grizley Tools (they have a web site) . Fairly inexpensive, came in a complete kit (with case) and seems to be quite accurate.
Old Nov 30, 2004 | 02:44 AM
Turbo-Jet's Avatar
Turbo-Jet
Thanks!
dial indicators range in price from $20 to $200, and you pretty much get what you pay for. however, i've found even the cheapish $50 made-in-china ones are ok for most general auto/engine uses.
Mitutoyo and Starrett are good but $$$
you probably want a plunger style 0-1" range with .0005" graduations. And digital is not always better...
try Reid Tool or McMaster-Carr. they are good reputable vendors.
Old Nov 30, 2004 | 06:56 AM
Gordonm's Avatar
Gordonm
I have a Mitutoyo myself but I am in the tool supply business so I got mine for free. I have dial indicaters and mics and calipers. Some digital some not. The digital ones are easy to read and if your not used to dials they can be tricky to read. The cheap ones are cheap. If you only use them on occasion the ywill probably be OK. Mine was around 100 with a stand at cost. Get a decent one but no need to spend huge $$$ on one.
Old Nov 30, 2004 | 08:49 AM
stingr69's Avatar
stingr69
I have Harbour Freight cheapie Cen-Tech specials. I do not use them a lot so I did not sink much into the stuff. I could not say anything bad about them. Less than $20 each for a magnetic base and a dial indicator. Get an analog readout, not digital. You can see a lot more things happening with an analog dial.
-Mark.
Old Nov 30, 2004 | 08:53 AM
Edzred72's Avatar
Edzred72
Gonna do rear wheel bearings soon. I'm watching this too.
Eddie
Old Nov 30, 2004 | 09:03 AM
Eddie 70's Avatar
Eddie 70
Ci 6, 8 & 10 Veteran
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15
I bought a kit from Harbor Freight. I believe it was Centech. If you are going to be doing a lot of work, I would go for a better piece than this. I wish I had bought something better, but I have used it to check rotor runout and bellhousing runout and it has worked fine every time I have called on it. I also bought a digital dial caliper from the same place and it measures .0005. Seems to work pretty good also. I hate buying Chinese crap but I could not see giving the price for Starret only to use a handfull of times.
Old Nov 30, 2004 | 09:32 AM
mandm1200's Avatar
mandm1200
-Mark.
Same here. I got the dial indicator and magnetic base. For as much use I will get out of it, it will last a lifetime. I used it for the rear wheel bearings and soon for the engine build. After that I thinking it will be on the shelf for a long time.
Old Nov 30, 2004 | 10:23 AM
comp's Avatar
comp
i have cheap to mid priced,,, i check them by setting on Zero on flat steel and sliding a feeler gauge under tip to see if it is the same as the thickness,,, ShadeTree
Old Nov 30, 2004 | 01:00 PM
pws69's Avatar
pws69
I agree - I have several from Harbor and Grizzley and like the Griz pieces better. The kits are a great deal and accuracy is way better than 'adequate' for anything but very high precision work.
Old Nov 30, 2004 | 01:14 PM
cicch95's Avatar
cicch95
Finalist 2020 C4 of the Year - Unmodified
Hey guys.....I have a few high quality....starrett, brown and sharpe, etc.....indicators I am going to be selling. I have some magnetic bases, and some other accesories.....I will have to see what I have. If you are interested......PM me or email me at cicch95@***.net. I am selling them as I was a machinist for 12 years, for the past 5 years I am in management so I don't need my tools anymore!
-Rick
Old Nov 30, 2004 | 09:22 PM
matchframe's Avatar
matchframe
Thanks for all the replys! Now I know what to look for.
Cicch95, I would be interested in one of your dial indicators, but I would have to wait until after Christmas.....have to think of the kids first!
Old Nov 30, 2004 | 09:44 PM
w1ctc's Avatar
w1ctc
One rule is to get a gauge that is 10X the resolution of
your mesurment. If you need measure to .001, the gauge should have a resolution of .0001. Also, have on hand a master of known dementions the check the gauge over a good part of its travel. This is more important with digitals.
Bob
Old Nov 30, 2004 | 10:28 PM
toolking's Avatar
toolking
You can also look here.
http://www.grainger.com/Grainger/sea...ults.jsp?xi=xi
But the used stuff might be the best low cost alternative.
To (Tools) Dial Indicators
