Coupe vs. Conv. Doors
Old Nov 30, 2004 | 02:21 PM
BDVT69's Avatar
BDVT69
Default Coupe vs. Conv. Doors
Besides the glass, what is the difference between a coupe and convertable door. Will a coupe door line up on a convertable.
Old Nov 30, 2004 | 03:13 PM
markdtn's Avatar
markdtn
No, you can't use a coupe door on a vert (except 68-9). In the upper portion of the rear of the door is a pocket on a vert. The male line-up pin goes in this pocket. If you took the female line-up receiver off the body it would work, but I think the car becomes much looser. Line-up pins were used in 70-75, not in 68-9. You can buy the pockets from Paragon and weld them onto a coupe door if you can't find a good vert door.
Old Nov 30, 2004 | 03:37 PM
BDVT69's Avatar
BDVT69
I have a 69 vert and bought a couple of 75 coupe doors.
Old Nov 30, 2004 | 04:40 PM
markdtn's Avatar
markdtn
That should work. There are some little brass plates on the jamb I believe. You need those.
To Coupe vs. Conv. Doors
