What do I check ?
Old Nov 30, 2004 | 07:35 PM
TARTAN2's Avatar
TARTAN2
Default What do I check ?
Hopefully buying my first vette this weekend and would appreciate all the help I can get . Its a 68 T-Top
What should the gauges read when the car is warmed up ?
What temp should the rad fan kick in ?
What can I check on the steering and suspension ?
Any other advice would be a great help and if anyone has photos of how the underside should look please e-mail me .
I read the posting on "Frame Rust" - Point taken
Many thanks
Old Nov 30, 2004 | 07:41 PM
carl a's Avatar
carl a
they didnt have electric radiator fans back then ,,unless its a up grade- as far as coolant temp , my stroker runs under 200- like 198 or so- i believe big blocks run hotter, its been so long since i had one i dont recall,vettes run hot. also power steering leaks on these cars a lot-there.s a ram under there cuz of lack of room. depends what psi oil pump ins in there,40 to 60 i would think, im sure others will chime in here
Old Nov 30, 2004 | 07:43 PM
Nowhere Man's Avatar
Nowhere Man
2015 C2 of Year Finalist
what kind of engin is it? big block, or small block
Old Nov 30, 2004 | 07:51 PM
Wife'sVette's Avatar
Wife'sVette
oooh, first check the drool and if it is on the chin .... BUY IT .......Robert
Old Nov 30, 2004 | 08:06 PM
OHSIXX's Avatar
OHSIXX
C2 of Year Finalist (performance mods) 2019
Take someone with you and listen to what they say. Two sets of eyes are better.
Another tip; do not buy the first one you look at.
Old Nov 30, 2004 | 08:20 PM
TARTAN2's Avatar
TARTAN2
327 small block - auto 3 speed [ M20 ]
Old Nov 30, 2004 | 08:25 PM
TARTAN2's Avatar
TARTAN2
Old Nov 30, 2004 | 08:27 PM
Eddie 70's Avatar
Eddie 70
Ci 6, 8 & 10 Veteran
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15
M20 is a manual 4 speed tranny.
Old Nov 30, 2004 | 08:29 PM
TARTAN2's Avatar
TARTAN2
I'll check the code !
Old Nov 30, 2004 | 08:31 PM
TARTAN2's Avatar
TARTAN2
Old Nov 30, 2004 | 10:03 PM
wills670's Avatar
wills670
be careful and don't be bashfull. ask questions and look over very carefully if the owner does not want you to look at very close run away. if they have nothing to hide they will not mind you looking around. if you look at previous post you will get plenty ideas of were to look for trouble. also pay attention to the little things they add up quick.
Old Dec 1, 2004 | 12:05 AM
ewalker302's Avatar
ewalker302
I would suggest printing this out and taking it with you.
http://www.samarins.com/check/checklist.html
I always take a checklist when looking at used cars, especially corvettes or any other exciting car. It's real easy to overlook something, even if you take a long time.
Really helps me to stay focused on what I'm doing, which is looking for problems.
Also, after going through it, then you can start worrying about the vette specific stuff with a clear head.
To What do I check ?
