Very stupid question
Old Dec 1, 2004 | 07:12 AM
copter's Avatar
copter
Default Very stupid question
I would like to drain my cooling system on my 82.Can anybody tell me where the radiator drain plug is.It looks like it's inclosed by some plastic pieces. :o
Old Dec 1, 2004 | 07:37 AM
carl a's Avatar
carl a
you can always un- clamp the lower radiator hose
Old Dec 1, 2004 | 09:12 AM
copter's Avatar
copter
That was one of the things I thought about.
Old Dec 1, 2004 | 09:14 AM
comp's Avatar
comp
probably was a new one
Old Dec 1, 2004 | 09:22 AM
page62's Avatar
page62
Lower right-hand side of the radiator -- should be a brass petcock. Easy to see. But perhaps yours doesn't have one...
Old Dec 1, 2004 | 12:31 PM
CA-Legal-Vette's Avatar
CA-Legal-Vette
Removing the lower hose works quite well though.
Old Dec 1, 2004 | 12:39 PM
GTR1999's Avatar
GTR1999
Certainly not a dumb question. I was under an 82 last week and noticed there was a plug in the radiator instead of the petcock drain. This was a very original car too. You can pull the lower hose but they can be a bear to get back on sometimes and may be stuck. I would check the for the plug in the lower right corner or buy one of those drill pumps that use a garden hose to pump out the radiator. I used one and it worked pretty good, drained about 95% of the radiator.
Gary
Old Dec 1, 2004 | 01:34 PM
Brettmc's Avatar
Brettmc
I can't help with your problem but I can tell you this...the only dumb question is the one not asked.
Brett
Old Dec 1, 2004 | 02:27 PM
LOTAHP's Avatar
LOTAHP
Old Dec 1, 2004 | 03:43 PM
i885744's Avatar
i885744
alot of the reproduction radiators don't have one. I've got a 75 radiator without one. Its not that hard to pull the lower coolant hose off. Plus you get the added bonus of getting coolant all over the garage floor when you do it.
Old Dec 1, 2004 | 03:57 PM
djcwardog's Avatar
djcwardog
Better to ask than to guess - do a Bubba - and then be on here asking how to fix what you did... Don't ask how I know!
Old Dec 1, 2004 | 03:58 PM
DropTopBigBlock's Avatar
DropTopBigBlock
on some radiators, especially if it's a replacement, the petcock may be under the radiator mount, where you can't get to it. yank the hose.
Old Dec 1, 2004 | 04:14 PM
CA-Legal-Vette
Well said. Want to know how I found out what antifreeze tastes like?...
Old Dec 1, 2004 | 04:26 PM
kdf1986's Avatar
kdf1986
On my 73 I have a bolt at the bottom of the radiator under the lower radiator hose location. If you are facing the car, it would be on the lower left side of the radiator.
kdf 1973 454
kdf 1986 L98
Old Dec 1, 2004 | 05:32 PM
Budizzo's Avatar
Budizzo
Brett
There is no such thing as a stupid question, only stupid people who ask questions
Old Dec 1, 2004 | 05:33 PM
copter's Avatar
copter
Thanks guys.At least I know where to look now. This is a very original car with the org. radiator.
Old Dec 1, 2004 | 06:58 PM
Yellow73SB's Avatar
Yellow73SB
St. Jude Donor '07
Old Dec 1, 2004 | 07:23 PM
Guru_4_hire's Avatar
Guru_4_hire
Cruise-In IV Veteran
Cruise-In V Veteran
Since the lower radiator hose might not come off so well, you can always just poke a hole in the hose and buy a new one. Mine was stuck on there and no amount of anything would bring it off so I just cut it off and bought a new one.
To Very stupid question
