Engine storage tips
Old Dec 2, 2004 | 11:53 AM
Chumpzilla's Avatar
Chumpzilla
Default Engine storage tips
Need some suggestions. I'm in the middle of a body off resto and my engine work is complete... The engine is fully assembled and sitting on the stand... the oil pressure and compression have been tested.. the manifolds and sheetmetal are on..... It's been that way for about 4-6 weeks so far... I had anticipated having the engine in the car by the end of the year, but it looks like it might be a little bit longer... perhaps january or february.
My question is this... is there anything I should do to the engine to keep it in good shape over the next few weeks until I get it installed and cranked for the first time? Should I turn the crank over every once in a while or anything else? Everything is taped off so nothing can get in.... I'm just wondering what else I should do to ensure no problems arise.
Thanks.
Old Dec 2, 2004 | 02:28 PM
Z-man's Avatar
Z-man
I wouldn't do a thing to it except take pictures...
Old Dec 2, 2004 | 07:05 PM
MEGALADON's Avatar
MEGALADON
From: WAY DEEP INSIDE AMERICO,YES YOU LIVE HERE TO!! TX
for the standing period, I would cover it in a big plastic bag
Old Dec 2, 2004 | 07:16 PM
Jughead's Avatar
Jughead
Senior Member since 1492
From: Just because I'm paranoid doesn't mean people aren't out to get me...
St. Jude Donor '09
Sound like when I did my engine. I turned the crank every couple weeks just to be sure..more to ease my mind.
Cover with a plastic bag. I also put about 10 qts of oil in the pan and cranked her several times...don't forget to remove the oil when storage time is over.
Old Dec 3, 2004 | 09:09 AM
Chumpzilla's Avatar
Chumpzilla
... it's covered in plastic... and that's about all I've done.
I'll turn the crank every couple of weeks just for ease of mind...
Thanks all.
Old Dec 3, 2004 | 10:13 AM
bobs77vet's Avatar
bobs77vet
From: Arlington Va Current ride 04 vert, previous vettes: 69 vert, 77 resto mod
... just turn it over occasionally.... to move the valve springs
To Engine storage tips
