crank and pistons
Old Dec 2, 2004 | 02:42 PM
MYBAD79's Avatar
MYBAD79
St. Jude Donor '05
Default crank and pistons
I am not going to install this soon so there's a lot of time to figure out what I want and what I need....
I have the L48 block with the 2 bolt main and low compression. I want to upgrade my crank and pistons. Jegs has forged pistons that would give me 10.2 CR with the 64cc heads which I already have. These are reasonable priced, does anybody have experience with these or what would you recommend ?
The crank: Is a forged crank necessary or can I re-install my old crank with new bearings, rods and pistons ?
The cylinder bores looked fine last time I had a look at them... I guess honing the bores is not necessary or should I have that done anyway ??
Old Dec 2, 2004 | 05:43 PM
GTR1999's Avatar
GTR1999
I'm starting the same job now. 72 base motor which is like yours. The cylinders look good so I'm going to measure them and have them honed with a torque plate. The piston and rods also look to be fine,the motor only has 55k miles on it.
Depends what you want out of it. In my case I'm going to use store the stock heads and use (67cc 202/160) SR Torquers that I port and polished, HE260 cam, performer intake, headers 2.5" pipes, stock ignition, and either a 670 Holley avenger or 750 Q-Jet carb. I'm guessing the CR will be about 9:1 using these heads and the stock pistons. I'm running a B&M prepped TH400 with a prepped 3:08 rear gear. This motor might be 300 hp and 350? ft/lbs just about right for the combo I have.
Gary
Old Dec 3, 2004 | 04:52 AM
WESCH's Avatar
WESCH
Hi
I asked a similar question for my 427 BB and the answer was that if you reuse old some old parts, the complete assy must be fine balanced.
So at the end its a price question to either buy a complete rotating balanced kit or single parts and getting them balanced.
Good luck. Gunther
Old Dec 3, 2004 | 04:41 PM
marshrat99's Avatar
marshrat99
1) The Jegs combo sounds fine. I went with a similar one from Scoggins-Dickey.
2) A forged crank is not necessary if you're planning on staying below a 5,500RPM redline and you're not considering running NOS. For a NOS application, your 10.2CR will be too high anyway.
3) You can save some $ by reinstalling your old crank. In doing so, unless you've got the capabilities, you'll have to get a machine shop to a) check the block to see if needs align bored, b) check for warped crank and possibly turn and c) check crank for wear and possibly turn. Even with a new crank, a) & b) will need to be done.
4) Your cylinder walls need to be checked for perfect roundness and will at least have to be honed to within whatever thousandth of an inch piston-to-wall clearance is recommended by the piston manufacture. Again, this is a job that needs to be done by a good machinist.
Hope this help.
Old Dec 3, 2004 | 05:07 PM
Fevre's Avatar
Fevre
Now is the time to look into a 383 rotating assembly, have seen many for less than $900 fully balanced with flexplate and balancer.
Old Dec 3, 2004 | 06:39 PM
MYBAD79's Avatar
MYBAD79
St. Jude Donor '05
For a while I thought that I could change the crank and pistons with the engine installed - if (and this is a big IF) the bores are in very good shape...
I am convinced that it's smarter to remove the engine and have the block machined.... now this is definately the time to look into the 383 stroker kits...
The rotating assembly is around $1000 - Golan for example offers the complete assembled 383 block, balanced and installed rotating assembly and all the new bearings for $1999 - I wonder if that's the better deal... instead of rebuilding my block...
To crank and pistons
