Help with Dash Pad Install.
Old Dec 2, 2004 | 11:48 PM
MattCrunk's Avatar
MattCrunk
Default Help with Dash Pad Install.
I just got hold of a good original top dash pad to replace the sun-cracked one in my 76 Coupe.
I've never installed an upper dash pad, but I've removed a couple and remember them binding between the windshield posts and having to be bent in order to get them out.
As this is a 30 year old part I'm installing, I hate the idea of bending it to get it in past the posts, for fear of breaking/cracking it.
Any suggestions?
Old Dec 3, 2004 | 02:01 AM
checklst's Avatar
checklst
You will have to bend it a little, just make sure the part is warm. I left my new one out in the hot sun upside down for a few hours and it really softened the backing so the bend was easy.
I would hate to try this in the winter!!!
Old Dec 3, 2004 | 07:13 AM
igo4vols's Avatar
igo4vols
Yep - bending is the only way. Don't forget to remove the windshield post trim first. Don't ask why I say this.
Old Dec 3, 2004 | 07:18 AM
Razorhorn's Avatar
Razorhorn
You also need to be careful about the defrost vent deflector. If you bend the dash pad too much you'll break off a connection point on the deflector.
Old Dec 3, 2004 | 08:28 AM
Edzred72's Avatar
Edzred72
I would suggest wrapping both ends with towels. Prevents the corners from scratching during install.
Eddie
Old Dec 4, 2004 | 02:05 AM
C3 Stroker's Avatar
C3 Stroker
Any suggestions?
When I replaced my interior, I had very good success by using a heat gun for gentle bending.....just be careful not to overheat any one spot & everything should fit smoothly.
To Help with Dash Pad Install.
