LS1 Conversions HERE!
Old Dec 3, 2004 | 10:57 PM
70 LS1's Avatar
70 LS1
Originally Posted by turtlevette
that cast aluminum oil pan doesn't give me warm fuzzies.
It'll be fine, just don't hit anything.
Old Dec 3, 2004 | 11:06 PM
Budman68's Avatar
Budman68
Cruise-In VII Veteran
St. Jude Donor '07
what do these thing run in the quarter in a c3. anyone got any timeslips?
If I could keep my front wheels on the ground, I might be able to go the whole 1/4. Easy 13's, 12's with slicks are not uncommon.
Old Dec 4, 2004 | 12:26 AM
79ls1's Avatar
79ls1
Originally Posted by Budman78
I split the bracket that holds the end of the ram and welded in a 1" of plate stock. After grinding it down, it looks just like original. The ram now clears the pan at full right hand turns.
That sounds like a simple (good) solution. Good luck on the coil-overs.
Turtle: As fast as I can push it.
Old Dec 5, 2004 | 04:22 AM
holley505's Avatar
holley505
79ls1 where did you get your mounts for the engine and tranny? also are you running your AC?
Old Dec 5, 2004 | 07:39 AM
79ls1's Avatar
79ls1
Got the mount adapters from S&P, crossmemeber from Bowtie Overdrive. I am running A/C. Used S&P acc drive, Sanden Compressor to accomplish this. Be forewarned, it was the most expensive part of the project save the engine, but they go make nice stuff. It's much cheaper to do what Scooter, Budman, 70ls1 have done. They made their own but I don't know who if anyone is running A/C.
Old Dec 5, 2004 | 09:24 AM
Budman68's Avatar
Budman68
St. Jude Donor '07
No a/c yet. I think I'm going to run the S & P stuff myself. Not a big priority, since I can count on one hand how many times I've used it in the past on one hand. I'm 6'2", so putting the t-tops on is the last think I want to do.
