Hi beam indicator light
Old Dec 5, 2004 | 08:33 AM
Ybnormal's Avatar
Ybnormal
Default Hi beam indicator light
Does anyone remember where the headlight high beam indicator bulb is on an 81. I noticed mine was out last night and need to check the bulb.
Thanks,
YBnormal...drive a vette
Old Dec 5, 2004 | 09:20 AM
ICEMAN59's Avatar
ICEMAN59
On my 80 it is between the speedo and tach. It is easy to get to if you remove the lense covering them. You can pull the bulb out of the front. You can also reach under dash and the whole light assy will twist out and the bulb can be replaced that way. Hope this helps.
Keith
Old Dec 5, 2004 | 09:34 AM
Ybnormal's Avatar
Ybnormal
Thanks ICE, is that the only indicator light bulb between the speedo and tach? I want to make sure I get the correct one.
To Hi beam indicator light
