This Forum Has Too Many Postings!
The only down side I have is when I went to find an old thread on mine it was on page 13 after a week. And the search function would not find it (even by name). I am a little annoyed with the search function.
You're not alone.
: I can't find any of my engine posts from 2002-2003!
I learn a lot on this forum, but I also enjoy the "small talk".
It's time to move on.......
The reason I like this forum is because there are new threads almost hourly, the other forums you can check once a week and if your lucky you might get one or two replies to your post
That's how I view the forum, having all the discussions together, I can eaves drop on everybody's conversation and add some comments IF I want. If we were to split the forum up, I'd have to go to another members garage to hear what the other guys are talking about.
Oh, and actually there might be one guy helping me diagnose my carb problem.
In think Al Gore is still down in Fla counting ballots.
Seen Gore @ Dunkin' Donuts just this morning, still with his calculator.
:If you search the following you will get posts back to 08/2001
use your jughead in the "search by user name" note you can find either posts or threads started by you.
Then under search options, at the second choich down "find posts from", select yesterday and the move over to the and at the right and select the older option.
I got 2pages of threads and four of posts going back to 08/2004.
PS: forgot to say use the advance search feature
Hope this helps you.
It certainly is set up to retain posts for too long. If you look, you can actually scroll past to a thousand pages of postings. It should retain things for 30 days and that's it.
Just my humble opine.
I tried every combination possible....Nothing for me for 2002-2003.
Even Troy tried. If you find any from 2002-2003 could you email me the links?
bigdaddyrat454@gmail.com
...redvetracr
...redvetracr
Pete
I don't have a solution to this problem. Some posts are so extremely vague, I never even look at them. Others, are of obvious little interest to me. A lot are quite interesting. I wish we could keep the highjackings and the meaningless posts to a minimum. (I really don't care about a survey on how many owners have black Corvettes in any model years.)
I will tell you one thing that doesn't help, breaking the C3 forum into a lot of subsections.
I regularly help the Chevelle and Camaro enthusiasts. The have many, many different subforums. All that does is make me look at even more
places because I might have questions in the following subforums:
Tech 2004 Can I change a column shift strg colum for a floor shift column? -- what additional parts do I need?
Restoration Centers What color is a 67 Chevelle strg column? -- does it fit a 1968?
Brakes and Suspensions Do I need a new steering column if I
change to power steering gear?
Electrical & Wiring Is my turn signal switch bad? How do I tear my steering column apart to change it?
Troubleshooting Why don't my turn signals work? -- Flasher unit? Bulbs? Strg Column?
Guess what? There is a possible steering column question involved in most of the above. Each question could involve a couple different areas. You need to read each of the postings to find out exactly what is wrong or how things can be corrected.
The Chevelle and Camaro forums could use less catagories. Maybe the Corvette Forum could use one or two more.
I wish that I had a good solution.
As the BOYZ say, WTF!!
Ok here's my 2 pennys so find a chair to either sit on or smash the tube with.
This is just a big public party for vette owners and mtr heads too. We may have to deal with all levels of experience and mentality but it is basicaly free. I feel i've met some very nice people here and learned a lot too. Gotten some vital info just when i needed it.There is no fix to making every post an enlightening experince otherwise i'm sure it would be in use already. And we are all humans that even when having all good intentions can make mistakes and errors - some big mistakes too.
It burns me up when someone continues to spread what i think is BS
I've seen copy cat vette forums that look just like this one but they have limits on use/posts and don't seem as alive as this place in space. With supporting user features i can get pretty much read what i want how i want it and for free. The only feature i would like to see expand is the tech section and maybe use some type of pro vs con or how to vs don't do it rebuttle statments for popular technical problems.
Well that my song for today and hope u enjoyed the tune.
cardo0
