making mufflers...
Old Dec 4, 2004 | 11:58 AM
'77BABE's Avatar
'77BABE
Default making mufflers...
Trying to make stainless steel mufflers for sidepipes. (first attempt made them louder) Has anyone tried this? Any tips?
Old Dec 4, 2004 | 12:01 PM
Twin_Turbo's Avatar
Twin_Turbo
What are you using? perforated pipe w/ stainless wool or some type of disc setup?
Old Dec 4, 2004 | 12:09 PM
comp's Avatar
comp
did yr's ago made like glass pack's
Old Dec 4, 2004 | 12:27 PM
'77BABE's Avatar
'77BABE
Got Hooker 4" side pipes, ceramic coating. The first ones were made of several stainless steel pipes welded together, in the shape of an O filled with o 's. (if that description helps)
Thinking of making a perforated cone...
How long have the 'glasspacks' lasted?
Old Dec 4, 2004 | 01:15 PM
Twin_Turbo's Avatar
Twin_Turbo
stainless wool lasts forever
Old Dec 4, 2004 | 05:01 PM
1979toy's Avatar
1979toy
Have you looked at these?
I am using one of these in each side with the center hole open. It is too loud for real street driving. Two in each side with the center hole blocked may be a better choice.
Old Dec 4, 2004 | 05:21 PM
Master Ho's Avatar
Master Ho
Check with big632; he has some.
Old Dec 5, 2004 | 05:15 AM
'77BABE's Avatar
'77BABE
Thanks for the tips
Old Dec 5, 2004 | 08:37 AM
BB wowbagger's Avatar
BB wowbagger
I made these for my pipes and they work out really well. They deliver a nice rumble at idle and makes a really nice sound at wot
Old Dec 5, 2004 | 08:54 AM
MYBAD79's Avatar
MYBAD79
St. Jude Donor '05
Summit offers stainless mufflers in 3.5" outer diameter (24" or 30" long) - these could be welded in a 4" sidepipe ...
Page 75 in their catalog, item # sum-630630
Old Dec 5, 2004 | 12:03 PM
'77BABE's Avatar
'77BABE
What materials did you use and how did you go about making them? They look interesting.
Old Dec 5, 2004 | 12:06 PM
'77BABE's Avatar
'77BABE
Thanks for the tip, but I need to be able to take them out so I can slip in the current resonator for inspections... I don't have a problem with the loudness, but police may
Old Dec 5, 2004 | 12:32 PM
BB wowbagger
They are made of 3" perforated tubing and the rods are welded in position. The absorbing material is steelwool.
To hold them in place i drilled a hole in the pipes and welded a nut on to the muffler. Then just bolt it down.
Old Dec 5, 2004 | 03:18 PM
NHvette's Avatar
NHvette
How much do you want to spend ... $330 gets you a nice set of spiral turbos :
You can certainly fab something up much cheaper, but I have
heard nothing but great things about these baffles.
Old Dec 5, 2004 | 04:45 PM
yellow 72's Avatar
yellow 72
St. Jude Donor '09
I still like my $20.00 Dynomax Magnum glasspacks...IMO best sounding sidepipe muffler out there....and I've tried a few.(including the exalted spiral baffled)
Old Dec 5, 2004 | 04:55 PM
comp's Avatar
comp
iv'e never seen a test on those....Has anybody ????
Old Dec 5, 2004 | 07:04 PM
69ttop502's Avatar
69ttop502
Comp, I was probably one of the first to dyno test the JCL baffles on my 69 with a 502. The gist of it was that I only lost 6 horsepower from open sidetubes on a 350 rwhp motor. This was with the caps still on the baffles. The amazing thing was I lost 92 horsepower with the Hooker mufflers. I absolutely love the sound of them as well. Now my motor is making over 600 horsepower and I am running the baffles uncapped and cut some. In this configuration on an engine dyno I only lost 12 horsepower. Pretty impressive in my book. They are expensive but I wanted to run sidepipes and make horsepower and I think these are the best way outside of running open sidetubes. Period.
To making mufflers...
Old Dec 5, 2004 | 08:19 PM
Mako72's Avatar
Mako72
2018 C3 of Year Finalist
After seeing how pathetic the Hooker mufflers were, I fabbed up a set of my own. I used some 2 1/2" Purple Hornie glasspacks, welded them up so they would locate inside the sidepipes correctly. They made great power but were way too loud. I went with the JCL spiral baffles and have been very happy with them.
Old Dec 6, 2004 | 02:27 PM
75 Stingray!'s Avatar
75 Stingray!
I made these prototype mufflers to see if I could make an adjustable side pipe muffler. End result: uncapped they were as loud as open headers, with the baffle on it wasn’t much better. It’s hard to see in the picture but there was a gap around the outside edge of the removable baffle and the 4” side pipe.
Old Dec 6, 2004 | 03:35 PM
PatsLs1vette's Avatar
PatsLs1vette
http://www.speedwaymotors.com/xq/asp...qx/product.htm
i made my own set with these,welded 3 sets together.
