Headlight Actuators rebuild?
Old Dec 5, 2004 | 07:50 PM
ESU's Avatar
ESU
Default Headlight Actuators rebuild?
Have a 79 coupe with a vacuum leak at the headlight actuator on the passenger side. I pumped the drivers side up to 10 inches mercury and it held for 15 minutes. The passenger side leaked down to 8 inches after just a minute or so and continued on down slowly after that. Was thinking about one of those boot/seal kits but was wondreing if it could be done while on the car? If it has to come out wouldnt it be worth just changing the whole thing. I realize the cost is alot different but was thinking about how much my time is worth.
Passenger side light comes up about 7-9 seconds after the drivers side does when the headlights are turned on.
Suggestions appreciated as always,
Thx, ESU in NY.
Please Remember 9-11 and support our troops overseas!
Old Dec 5, 2004 | 08:23 PM
kona's Avatar
kona
Can't imagine what a pain it would be to do the rebuild while the actuator is still on the car. But I do know this if one side is bad the other is sure to follow. I personally would do them both at the same time.
Just my Two cents worth.
Kona
Old Dec 5, 2004 | 08:48 PM
Glassbowtie77's Avatar
Glassbowtie77
Kona
Old Dec 5, 2004 | 10:02 PM
Jack71's Avatar
Jack71
No, it can't be changed on the car, unless you have a fetish for pain and aggravation. Your leak down is not that bad at all. Two inches in a minute is no big deal. I wouldn't mess with it, plus it could be leaking internally.
It is nice to finally meet somebody who is equally bothered by vacuum leaks though.
Old Dec 6, 2004 | 09:17 AM
ESU's Avatar
ESU
You're right about the leakdown not being too bad , however, my main problem is the minute I turn on the headlights my a/c starts blowing out the floor duct instead of the dash ducts. Same thing if I have the defogger on, it blows out the floor as soon as I turn the headlights on. This is my main reason for replacing/repairing the actuators and/or relay valves. All the hoses were replaced already.
Old Dec 6, 2004 | 10:48 AM
kona's Avatar
kona
Did you replace the check valve aswell? And those plastic tees?
Kona
Old Dec 6, 2004 | 10:52 AM
427basketcase's Avatar
427basketcase
I just installed a kit in mine. They are easy to do, OUT OF THE CAR
It takes a little finesse to remove them, but it is not too bad. I would recommend doing both while you’re at it.
Old Dec 6, 2004 | 12:54 PM
72GACRZR's Avatar
72GACRZR
Here's a link to a FAQ link on doing the seal replacement
http://www.corvettemagazine.com/2002...s/lights-1.asp
Old Dec 6, 2004 | 01:02 PM
ESU's Avatar
ESU
Kona
Check valve?? Not sure but all the tees were replaced.
To Headlight Actuators rebuild?
