Transmission cooler question...
Old Dec 5, 2004 | 10:55 PM
GrandSportC3's Avatar
GrandSportC3
Cruise-In IV-V-VI-VII-VIII Veteran
St. Jude Donor '03, '06, '17
Default Transmission cooler question...
I'll need a good transmission cooler with my new automatic transmission (TH200R4) because I'm going to use a 5000 converter and the tranny will run pretty hot... Any recommendations on a good cooler??
Old Dec 5, 2004 | 11:15 PM
73jst4fun's Avatar
73jst4fun
Using AN fittings? I installed a Moroso 3" pan first with studs, excellent quality, had a Derale pan on before and the rails warped...Perma cool uses rubber hoses or TCI high tech racing coolers use 6AN fittings ...keep us posted....
Old Dec 5, 2004 | 11:19 PM
lostpatrolman's Avatar
lostpatrolman
Keep the TKO and you wont need one...
Old Dec 5, 2004 | 11:33 PM
GrandSportC3
What type of fittings is better?? I was checking out the B&M 70266 cooler which comes with 1/2" NPT fittings... It's rated 28000 GVW. Don't know if this will be enough cooling for my tranny...
http://store.summitracing.com/defaul...tt=bmm%2D70266
Old Dec 5, 2004 | 11:42 PM
LOTAHP's Avatar
LOTAHP
I use (2) 1 ft. transmission coolers from Specialty Auto Tech. 909-608-7432 plus a deep pan from STEF'S
Old Dec 5, 2004 | 11:46 PM
GrandSportC3
Don't remember seeing 2 tranny coolers on your car.. Could you send me pics of your setup??
Old Dec 6, 2004 | 12:10 AM
mrvette's Avatar
mrvette
BEST bet, go to a recycling/junk yard and get a dual/parallel running 3/8 diameter condensor or evaporator from a room a/c unit, or smaller car, mount behind your present a/c condensor, and plumb to the tranny, without doing the radiator, just that cooler.....thing is large enough to cool anything....
GENE
Old Dec 6, 2004 | 12:23 AM
GrandSportC3
I actually just ordered the cooler in the link above.. I can still send it back if it's not what I need...
Old Dec 6, 2004 | 12:32 AM
LOTAHP's Avatar
LOTAHP
"O" you have mail. The coolers are located on the back side of the main crossmember.
Old Dec 6, 2004 | 12:40 AM
LOTAHP's Avatar
LOTAHP
I know LOTA people use those trany coolers in front of the radiator. The majority of us are always asking how to get cooler water temps. WELLLLL...get that tranny cooler out from in front of the radiator or not to have the tranny fluid run through the radiator. Some of you guys spend $400-$600 for an aluminum radiator and then just put hot tranny fluid in front of it AND it also blocks air flow through the radiator .
Old Dec 6, 2004 | 12:43 AM
LOTAHP's Avatar
LOTAHP
Hey "O". I'll help you make your decision REAL QUICK. My coolers were $80 each.
QUALITY FIRST . My TH350 or 700R4 has NEVER gone over 180*
By the way, the 180* was in traffic & playing around.
Old Dec 6, 2004 | 02:08 AM
carl a's Avatar
carl a
norm,,where's your cooler located at? behind the radiator i suppose, reason i ask is i still never installed mine, sittin in the box for almost 1 yr now....................i wish i could sleep,this insominia is really startin to take a toll on my body
Old Dec 6, 2004 | 05:16 AM
UKPaul's Avatar
UKPaul
I'm running a B&M cooler on mine to keep my 200-4r cool. Not sure if it's the one you've just ordered or a smaller one? In the last few months I posted the model number & GVW rating so you might find it in the archives. If not I can trawl through my HUGE box of reciepts & dig it out again if you want?
I've mounted it in front of the rad & plumbed it in so that the tranny fluid goes through the cooler before entering the rad. The result is that the trans fluid runs cooler and SO DOES THE ENGINE COOLANT!!!! I keep saying this & get the impression people think I'm full of but that is what happened. I've even removed all the old rubber seals around the rad (they were falling apart) & haven't bothered replacing them as I still don't have high temp problems. All of this could very well be due to not having the AC condenser in front of the rad.
As I've got the trans temp gauge I've found that I'm overcooling the tran fluid. In 1-3 gears (no lockup) the temp gets up to the recommended BTO value of 160(?) & not a lot higher. In OD with the converter locked the temps are 20 - 30 degrees lower. If I was to do it again I'd use the smaller of the 2 B&M coolers that were available locally (model no. in the archives ). Without a trans cooler the fluid temps were ramping right up, so much so that in heavy traffic I had to pull over once to let the thing cool down For driving in the low gears regularly with a 200-4r you definitely need a cooler, them temps soon start climbing if you spend any time with the converter slipping.
All testing was obviously done in this country, but we had temps of 100F locally one day & my poor engine took a hammering with no temp probs (coolant didn't get over 200 - prior to fitting the trans cooler the coolant was normally at 200!).
Old Dec 6, 2004 | 06:23 AM
1979toy's Avatar
1979toy
You folks that are installing trans coolers may want to look at a thermostat to warm the fluid up quicker while still cooling when needed. You can see one here
Old Dec 6, 2004 | 06:49 AM
UKPaul's Avatar
UKPaul
I thought about a thermostat but it's just something else to go wrong & more clutter on the car. By running the fluid through the rad on it's way back to the trans the hot coolant helps to warm it up.
Old Dec 6, 2004 | 08:31 AM
GrandSportC3
I already ordered my cooler.. and might get a second one.. The B&M racing coolers are only $56/each at Summit...
Old Dec 6, 2004 | 08:37 AM
comp's Avatar
comp
think about a fan also
To Transmission cooler question...
Old Dec 6, 2004 | 08:40 AM
Red73's Avatar
Red73
LOTAP, Can you post a pic or send to my email?
Old Dec 6, 2004 | 11:07 AM
gkull's Avatar
gkull
That's what I use the 8X11X1.5 B&M with 1/2 inch lines. No in and out of the water radiator and if I was worried about temp I would just go for the electric fan.
Mine is mounted at about a 45 degree angle about a foot in front of the radiator. I figured that when your not moving "Stagging" You need convection air flow. It works so well that I haven't really seen high heat levels
Old Dec 7, 2004 | 08:20 AM
GrandSportC3
I'll see how my transmission temps will be with that cooler.. If I'm not satisfied - I can always change to another cooler setup...
