Plugs are fine. Hotter plugs will cause pinging and not solve anything unless you are driving at slow speed in ftraffic all the time. Mine (current AC replacement of stock plug) are light tan with no deposits.
From: Arlington Va Current ride 04 vert, previous vettes: 69 vert, 77 resto mod
Originally Posted by Larry B.
They have a web site. Use (Max lead 2000).. It comes in 28 .oz bottle that they call a quart for some strange reason. Anyway I use 9-10 oz for 15 gals. So I get three fill up per bottle. 15 gal is good point for me to get gas so I can keep the ratio consistant but you can do it however you want. Each bottle cost $8 so ... less than $3 per tank. I duy it by the case.
edit: i may try this since i am taking the cats off of my new install and would like to get rid of the smells.....
you could run a pair of high flow cats. you can get ones with 3in inlets and outlets (or 2.5in or 2in). i could fit two in the same area as the stock one was orginally
i would think a pair wouldn't retard the performance much if at all
I just had some cats taken off, which were thoguht to be @ the time less restrictive, but once my new engine came together, the cats were a major bog on performance...it's an 80, 25 years, no more emissions inspections!
