Low Oil Pressure
Dec 8, 2004 | 06:01 PM
Low Oil Pressure
I need to check out the Oil pickup unit on my 76 L-48 engine. Do you know if I can get the oil pan off without having to drop the exhaust?
Jim
Dec 8, 2004 | 06:54 PM
Dec 8, 2004 | 07:18 PM
Dec 8, 2004 | 07:46 PM
From: Who says "Nothing is impossible" ? I've been doing nothing for years.
How many miles on the motor and whats the oil pressure ?
Dec 8, 2004 | 07:50 PM
142,XXX miles and its about 27
Dec 8, 2004 | 07:51 PM
Dec 8, 2004 | 07:58 PM
All....lol....no really, maybe 29 or 30 at cold but doesn't move with engine rev and is virtually the same from cold to hot
Dec 8, 2004 | 08:27 PM
Before you start pulling the engine apart, you may wish to have a shop do an external pressure reading and/or change your oil pressure sensor for about $25.00. That gauge has to move with RPM.
Dec 8, 2004 | 08:56 PM
Does it go to zero when you shut it off ?
Dec 8, 2004 | 09:33 PM
yes it does go to zero.... when I rev it up a bit and hold it around 2k RPM, I can here lifters asking for more oil.
