I posted this before, and I'm still having the issue. The jam nuts keep backing off on the adjustable struts, allowing them to turn and the camber to "self-adjust". (That can get disconcerting when you get out after a 80 mph run to see the wheel cocked!!!)
I know I can locktite / safety wire the nuts. This last time, one side loosened despite locktite and "turn it till it smokes and back it off a hair" torque down.
I really would rather know what would be out of whack that that would force them to loosen in the first place. I'm gonna call VBP for guidance and I hope someone here has some thoughts on it. Thanks.
i'm curious if u can possible drill a small hole on the rod and cotter pin it with a castle nut....or just put another nut on to lock them both.... is it possible to have them on backwards...... just curious..
A star shaped lockwasher or one with serrated sides will work. I am lockwiring mine but it's a lot of work and requires drilling a small hole in the lock nuts. Another option is replacing the locknuts with self locking nylon insert ones.
I would think the double nut solution would take care of the problem if there's room.
i was thinking the same thing to do with mine. i was looking at a friends vette and ask him if he had heard of it. he said no and i looked at his and bingo one of his was backed off. so i am sure i will be double nutting mine.
What are you going to anchor your lock wire to. I know from working on aircraft for a long time that that type if end joint usually comes with a groove on the treaded part with a special "washer" that has a tab the slides in this groove. The washer also has a tab that sticks up with a hole drilled in it to anchor the lock wire. I would like to know how you are going to do it because I think lock wire is the best solution. VBP should do this from the factory. I drew a crude paint drawing of what I am talking about.
I am going to wire the nuts on both ends together, so wire one nut, then in a helix shape go around the tube and then to the other one. The nut on one side is left hand threaded so the lockwiring is really easy.
How can VB&P lockwire it from the factory? The adjustment is different on all cars.
Good Idea. VBP could use the groove/washer method. You are still able to adjust it, then tighten the nut. The washer would be placed between the rod and the nut. The nut would then be lock wired to the washer.
I installed my VBP smart rods and their associated differential bracket last week end. When installing them I remember previous messages to this forum about troubles getting them tight. They really don't look like they're going to be easy to tighten. With all the problems discussed on this forum, I just wonder why VBP hasn't fixed this problem? I really don't want to use the full strength loctite since getting it loose can be a big problem. Particularly on these suspension parts that are subject to corrosion.
VBP warns that the nuts will back off unless torqued fairly tightly. i've had mine on 6 months with no problems. how much torque are you tightening them with??
I think you revealed the problem in the original post: "torque till it smokes, then back off a hair". The "back off a hair" destroys the torque effort, as the break away torque of the jam nut has been overcome, and it is now basically free to rotate with little effort. Torque it till it smokes and leave it and you'll probably not have the problem.
Mine loosened ... then torqued the snot outta them ... solid since.
That won't work - one of the nuts will be able to back off in the direction of the helix. If they were both right-hand it would work, but then you couldn't adjust them. Joe
Safety wire (Lock wire) is the best way to go. It's very strong if done properly, but it's a good idea to practice first. You want it to be tight, and you want it to "pull" in the tightening direction. Check this link: http://www.lrrsracing.com/RuleBook/lockwire.htm http://www.lrrsracing.com/images/Wiretie.gif
.032" is best. 020" & .025" breaks easily when you twist it, & .041" is a pain to work with & can be brittle because of it's larger size. Give yourself a good deal of wire to work with, at least 14" - 16". The trick to making it tight is when you finish the pigtail. Grab it with you pliers near the nut and turn it another one full turn. This adds a twist right at the nut & help pull the wire through the hole and puts tension on the wire. For .032 you want 6-10 twists per inch.
If you need to loosen or redo it, you'll have to use a new piece. Always add a "pigtail" by looping around the last piece, your hands will thank you later by not getting stabbed
