Help hood support
Old Dec 11, 2004 | 11:37 PM
vettepilot68's Avatar
vettepilot68
Default Help hood support
The bolts holdign my hood to the support are very weak and with the weight of the hood on the support appear to almost be pulling out of the hood. Since this is my first vette I am not sure of the best way to reinforce or repair this...can anyone give me some tips? should I lay some new fiberglass in the area and put in new holes? any info would be helpful.
Thanks in advance!
Old Dec 11, 2004 | 11:53 PM
68/70Vette's Avatar
68/70Vette
Is this a 68 Corvette? I don't understand what bolts you're talking about. The hood is attached in the front to two hinge brackets. Also the hood has an extention bracket that expands and locks to hold the hood in an upright position. What bolts are causing your problem?
Old Dec 12, 2004 | 09:34 AM
vettepilot68
Yes, its a 68...its the extension bracket that I am talking about...where it is connected to the hood...
Old Dec 12, 2004 | 09:56 AM
ManFromEagle's Avatar
ManFromEagle
I have the same problem with the under hood light that mounts directly above that. I was assuming there was some metal in there but as far as I can see it's just fiberglass.
I don't know about what you would do for the hood support but I was going to epoxy the holes smaller and just drive the mounting screws in again.
Old Dec 12, 2004 | 01:24 PM
vettepilot68
Thats the same kind of fix I was thinking about...anyone else been through this already?
Old Dec 12, 2004 | 01:26 PM
Red 69's Avatar
Red 69
I hope this pic helps, the support bracket bolts to the hood with two bolts.
There should be two nuts, or threaded bar inside the hood that the bolts go into. If they are there but rusted, try cleaning the threads or tap for oversize. If you had to, you could remove that section of hood, install new metal and glass it back in.
Old Dec 12, 2004 | 08:27 PM
vettepilot68
Red-Thanks for the pic. That info does help...its actually the other of the support (extension bracket) that is pulling out on mine, but I am guessing the same would apply.
Old Dec 12, 2004 | 10:22 PM
jeaux's Avatar
jeaux
heli coil thats what I did worked out well and it's cheap
Old Dec 12, 2004 | 10:41 PM
Love My 72 and 77's Avatar
Love My 72 and 77
I think you described your problem very thoroughly I understand exactly what you mean.
My 72 hood cracked all to crap right in that spot and I took the hood off and put a new piece of metal plate with two holes tapped into it to reinforce the hood and have a good base to bolt the hood support into.
My 68 came to me with one bolt in the hood and was still solid as hell especially after putting another bolt in it. I am assuming those hoods just were mistreated and got weak on your 68 and my 72. I would be careful with your hood is kind of hard to say without seeing the damage if it warrants reglassing the hood.
There is a metal plate in your hood froom factory
Old Dec 12, 2004 | 10:46 PM
Love My 72 and 77
WOW im glad you corrected me I might have gone through life thinking my "EXTENSION" was called a hood support and the hinges were not hinges but supports or something else hinge brackets. Now I will have to explain to my wife that in fact she cant call my EXTENTION and extension anymore
Old Dec 12, 2004 | 11:09 PM
vettepilot68
LOL...I let my wife read that one...she thought that was pretty good.
To Help hood support
