Hydroboost on corvettes
Old Dec 12, 2004 | 08:53 PM
gpowellpec's Avatar
gpowellpec
Default Hydroboost on corvettes
There was a thread awhile back about teeing into the power steering lines to add a hydroboost to a Vette. Wouldn't it be simpler to get a power steering pump and reservoir for a hydroboost system? Also doesn't the reservoir need to be higher than the hydroboost unit to keep fluid from seeping out the cap?
Old Dec 12, 2004 | 09:28 PM
ram82fire's Avatar
ram82fire
The master cylinder reservoir retains it's original position and the HB reservoir is in the power steering pump housing ,,,,,,,,,,,, no leak problems
Geo
Old Dec 12, 2004 | 09:59 PM
gpowellpec's Avatar
gpowellpec
I was not referring to brake fluid seeping out the cap. The low pressure power steering fluid return line on the hydroboost unit is at a highter elevation than the standard power steering pump reservoir. What is to stop the power steering fluid from flowing down the return hose and seeping out the power steering pump reservoir cap, which is lower?
Old Dec 12, 2004 | 10:06 PM
chevymans 77's Avatar
chevymans 77
St. Jude Donor '05-'06,'11,'13-'14,'16,'18,'19,'24, '25
The power steering reservoir is located in basically the same place on the vette as the trucks that we take the system off of and the hydra boost valve does not store fluid so the level of the valve is not an issue. You cannot tee into the pressure line of the power steering system. The pressure line has to go straight to the hydra boost valve and than from there to the power assist cylinder. The Hydra boost valve will proportion the fluid flow in order to keep both the brakes and steering working correctly. You can tee into the return line from both the hydra boost valve and the steering assist cylinder.
Neal
Old Dec 12, 2004 | 10:46 PM
ram82fire's Avatar
ram82fire
What he said so eloquently
geo
Old Dec 13, 2004 | 05:21 AM
gpowellpec's Avatar
gpowellpec
Neal, Are you saying you use the separate reservoir from the truck system on the Vette? That was what I was referring to in my original post. Using the hydroboost power steering pump with its separate reservoir. After more thought I realize there would not be enough power steering fluid in the low pressure hose to cause an overflow on the low mounted power steering pump reservoir (unless the pump was filled to the brim, which is an over full condition anyway).
Old Dec 13, 2004 | 12:33 PM
SharkPilot's Avatar
SharkPilot
There is something that I have been wanting to ask:
What is the advantage of using a hydra-boost in place of a vacuum booster? I am really curious abut this.
Thanks in advance.
SharkPilot
Old Dec 13, 2004 | 02:03 PM
kortensi's Avatar
kortensi
Thanks in advance.
SharkPilot
I can stop now
Old Dec 13, 2004 | 02:14 PM
427V8's Avatar
427V8
C6 the C5 of tomorrow
You get that wonderfull overboosted 1979 Volare' station wagon brake pedal feel. Just a feather touch and the brakes are fully on.
Old Dec 13, 2004 | 02:17 PM
SharkPilot's Avatar
SharkPilot
Originally Posted by kortensi
I can stop now
Okay I get that. Why wouldn't a vacuum booster work? Is the cam really radical causing low manifold vacuum? The factory used vaccum boosters with the L-88's so I would think that the cam would have to pretty wild to keep a vacuum booster from working right. Or am I missing something here? :o
Old Dec 13, 2004 | 02:44 PM
Garys 68's Avatar
Garys 68
SharkPilot
Big cam, low vacuum, blowers, clearace issues.
BTW, I noticed what looked like factory hydroboost on my GF's '04 Mustang. With the V8, it didn't look like there was clearance for the valve covers.
I've seen some vette projects, ie hydraulic clutch, tall valve covers, that didn't have clearace for the booster.
Gary
To Hydroboost on corvettes
