speedo sensor for 700r4
Old Dec 15, 2004 | 09:28 AM
PatsLs1vette's Avatar
PatsLs1vette
Default speedo sensor for 700r4
I need a speedo sensor for my new autometer mechanical guage.Since i have tpi i have an electronic speedo sensor in the 700 now.What i need to know will this autometer sending unit work with my 87 tpi setup.I know there 2 000 pulse and 4000 pulse but the autometer list theres as 16,000.I have the stock mechanical drive to put back in the tranny,but i need this adapter so i can the mechanical and electronic too.Painless has one for $93.00 and autometer is $65.
http://store.summitracing.com/partde...4923434+302575
Old Dec 15, 2004 | 09:45 AM
wombvette's Avatar
wombvette
I dont know anything about the autometer stuff, but here is what I did on my 66. I needed a mechanical drive on the speedo and needed an enectrical signal for the computer. I used the mechanical drive on the transmission and feed that into a mid 70s cruise control unit and on to the speedometer. I mounted a diode type sensor from an 85 Celebrity on the cruise unit to signal the compter. Works like a charm, cost nothing.
Old Dec 15, 2004 | 10:14 AM
PatsLs1vette
Thats fine my problem is i dont have any mechanical at all on the tranny just electronic going to my buffer to the computer.I guess ill call speed and performance and just buyit from them .
Old Dec 15, 2004 | 10:17 AM
Twin_Turbo's Avatar
Twin_Turbo
Why not get the VSS from a C4 vette and drop that in? You'd have to change out the drive & driven gear but that's relativly easy. I don't know about your autometer gauge but mine has a function to set the speedo to calibrate itself, as in drive a certain stretch and then the speedo will calibrate itself.
Old Dec 15, 2004 | 10:23 AM
PatsLs1vette
Ok i have an electronic vss in my tranny now hooked to my computer and i have a mechanical autometer speedo.I need to know if i can use the autometer sending unit for my 87 tpi. 85-89 is one and 90-92 is another.
Old Dec 15, 2004 | 10:27 AM
Twin_Turbo's Avatar
Twin_Turbo
Oh, a mech autometer gauge. I would ask autometer what the pulse per mile count is on their sending unit and check it against the GM one, if it fails I think painless sells a VSS to use on a mech drive cable.
Old Dec 15, 2004 | 10:40 AM
PatsLs1vette
Ill get a hold of painless,thanks
Old Dec 15, 2004 | 11:00 AM
Fevre's Avatar
Fevre
OK Pat why did you get a mech speedo if you have an elec sending unit?
Old Dec 15, 2004 | 11:25 AM
PatsLs1vette
Super good price that i couldnt pass up.Got tach and speedo together.
Old Dec 15, 2004 | 12:21 PM
markdtn's Avatar
markdtn
Also see www.jagsthatrun.com for more options on speed sensors
To speedo sensor for 700r4
