garage heaters.... i need one
Old Dec 15, 2004 | 08:27 PM
onaqwst's Avatar
onaqwst
Default garage heaters.... i need one
well,
due to michigan weather and the fact that my garage is a 2 and a half size and my vette is cold, i need a heater... i remember a post and people sharing what they use and recommend. i have a kerosene torpedo heater and i can't take it anymore..... fumes are getting to me... how much does an electric one cost and does it run off a 110 or 220? just curious.....
b
Old Dec 15, 2004 | 08:37 PM
Master Ho's Avatar
Master Ho
I'm checking out the duct work in my new house to see if an outlet can be added to my garage. It would be nice to have heat in the winter and cold air in the summer!
Old Dec 15, 2004 | 09:07 PM
an81shark's Avatar
an81shark
i saw an electric one at walmart last week, seems like it was under $50. it was an oil filled radiat kind
Rhufus's Avatar
Rhufus
If your house is heated by natural gas and you can plumb a gas line to your garage, I would suggest a Plaque heater.
Just added one to my 2 car attached garage and could work out there in my underwear.
A 3 plaque heater would be more then enough for a 2 car garage.
If you do not have access to natural gas then you could go with the Propane model, although it does cost more to operate.
Old Dec 15, 2004 | 09:21 PM
toyvet1's Avatar
toyvet1
Modine Hot Dawg 75000 btu keeps my 3 car nice and toasty. Not a big increase in my gas bill. Plumbed gas into the garage hooked up power and a thermostat.
http://hot-dawg.modine.com/?src=over...OVMTC=standard
Old Dec 15, 2004 | 09:26 PM
MikeC's Avatar
MikeC
The small electric construction heaters( ~5000Watts) will not keep you garage warm.... it will only take the chill off.
after screwing around with some ideas I plumbed in directly to my furnace. With the vent completely closed it maintains the temp at around 45 deg.... moves up to around 55 within an hour of openning up the vent. The only fear I have is fumes getting back into the house.... which I am currently working through.
Old Dec 15, 2004 | 09:29 PM
Red73's Avatar
Red73
Here is the heater that I just installed in my garage.
http://www.heater-home.com/product/G73.aspx
I just finished insulating and drywalling the walls and ceiling in my garage. I've been keeping the garage at 55 degrees. Tonight I turned the heat up (it's currently 28 degrees outside) temp in the garage is now 68 degrees and I just finished washing my wifes car. Yes I have a drain in the garage.
Old Dec 15, 2004 | 09:38 PM
greg454's Avatar
greg454
I have a finished 2 car garage and I can keep it 70* in 15* weather with this heater, but it runs alot. Maybe a little under size for a bigger or unfinished garage.
http://www.grainger.com/Grainger/pro...760791&ccitem=
Greg
Old Dec 15, 2004 | 09:48 PM
MotorHead's Avatar
MotorHead
From: Who says "Nothing is impossible" ? I've been doing nothing for years.
I bought a propane heater, runs off you BBQ tank and has a electric fan, says 55,000BTU and will heat 1200sq/ft you have to crack the garage door for ventilation, I am going to try it out this weekend
Old Dec 15, 2004 | 09:58 PM
Jughead's Avatar
Jughead
Senior Member since 1492
From: Just because I'm paranoid doesn't mean people aren't out to get me...
St. Jude Donor '09
Keep us posted. I'm running a 19,000BTU kerosene heater and gets the temp to about 40 when it's 20 outside.
Old Dec 15, 2004 | 11:22 PM
onaqwst's Avatar
onaqwst
red and greg...thats a nice heater ......i'll just have to see if i can pull a 220 line from my house to the garage and make a small circuit panel.... hopefully santa will let me use one for a minute or two..
b
Old Dec 15, 2004 | 11:42 PM
RMS73's Avatar
RMS73
I use two kerosene heaters, 23,000 Btu each, Use both to heat the 2-1/2 car garage up in about a hour and then run one. Today the AM temp was in the mid 20's and high was in the mid 40's. Worked on my truck in a tee shirt after lunch.
Roger
Old Dec 15, 2004 | 11:44 PM
76mike's Avatar
76mike
I live in California, it hasn't gotten below 60 in my 2-car ever, and I have no heater nothing.
Old Dec 15, 2004 | 11:55 PM
bobs77vet's Avatar
bobs77vet
From: Arlington Va Current ride 04 vert, previous vettes: 69 vert, 77 resto mod
Len i'm running the same one as you and a kerosene torpedo heater to get the air temp up rapidly...the torpedo htr smells, is too hot and is loud for all the time...but it does a great job immediately heating up the air. i figure i have the worst case scenario 24 x 34 detached concrete block...i started at 9pm tonight 20* outside just above freezing in garage and i just came in and it was 60* in the garage...i also use a small 8" round fan inside of 8" round duct work that is open at the top which is at cieling height and then open at bottom to recirculate my hot air fromthe top of the cieling (plastic sheeting) to ground level this is the real ticket to heat ...getting the hot air down to grnd level....
Old Dec 16, 2004 | 12:34 AM
onaqwst's Avatar
onaqwst
i think i'm gonna block off above the rafters with some drywall sheets or plastic..... i have a tall garage and could prolly make a mini office in the rafters.......
b
Old Dec 16, 2004 | 12:37 AM
gq82's Avatar
gq82
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
Here's a pic of my garage heater. It's a Lennox Hotshot 45,000 btu natural gas fired heater. It brings the garage up to temp in a matter of minutes. Thermostat control keeps it nice and toasty all winter long.
Old Dec 16, 2004 | 12:40 AM
Cali,68,L-79's Avatar
Cali,68,L-79
It was cold in the garage tonight so I opened the garage door and let the December 75 degree weather roll in.
To garage heaters.... i need one
Old Dec 16, 2004 | 01:43 AM
ACECO's Avatar
ACECO
St. Jude Donor '04 & '05
Show Off!
Old Dec 16, 2004 | 02:12 AM
Love My 72 and 77's Avatar
Love My 72 and 77
I bought this one from www.grainger.com
It is 200,000 BTU $133.00
here is a link
http://www.grainger.com/Grainger/pro...541199&ccitem=
Old Dec 16, 2004 | 06:31 AM
Sleper's Avatar
Sleper
I purchased a old oil heater 1960 from a oil company for $50. I then used a 45 gallon drum for oil which I fill via a 5 gallon can. Burn 25 gallons a year heating whenever I want. Works excellent. Only drawback is that it takes up floorspace. I have herd a furnace from a mobile home (Wall mount) works excellent. My $0.02
