Control Arm Bushings (HELP)
Old Dec 17, 2004 | 02:07 PM
norvalwilhelm's Avatar
norvalwilhelm
Originally Posted by JPhil
Use either a drill bit and drill a bunch of holes around the perimeter thru the rubber, or a hole saw without a pilot bit. Use a hacksaw blade if necessary to remove remainder of rubber till shafts can come out. Reassemble the hacksaw with the blade in the sleeve and carefully cut a groove most of the way thru it in two places. Cut a slot thru the flange section at your grooves. Collapse it with a cold chisel.
This is how I do it. I do not believe in pressing them back in either. They are too easy to deform
Old Dec 20, 2004 | 04:04 PM
80TexasC3's Avatar
80TexasC3
"Rodstoration &am p;quot; In Progres
Am now about 95% complete... paid to have them pressed out ($130) and new ones installed. Rest of the rebuild has gone very well... Just taking my time and making it look as new as possible.
Old Dec 21, 2004 | 06:53 AM
RDOldcars's Avatar
RDOldcars
Default A Arm bushing removal
Did mine last week, soak with P B Blaster for a couple days. Use an air chisel with a pointed end, be careful not to damage the control arm, took about 1 hour to do them. I pressed the new ones in with a large vice. O, don.t foreget to put in the new upper control arm rubber bumper stops, before installing the upper arms, if you don't, you will have to take it apart to install the rubber bumpers. Found out the hard way, Good Luck
Bob in Boca
