aftermarket distributors ???
my budget was running tight so i decided to "skimp" on a couple of things that were external so that i could easily replace them later...
such as the dist...
well...the time has come to upgrade it and i need advise...
those who know please advise me of my best alternatives...
MSD...Mallory...Accel...??? model numbers??? Summit links???
id like to keep it in the $300 MAX price range and NOT go to an ignition box....
i just want a nice replacement
i do NOT race the car and the engine is slightly modified...
probably around 300+ HP...
thanx for any advise...
I've always had very good experience with MSD quality and performance
You're gonna go over your $300 with just the dist. & box. I would definitely go with a box even if it is just a street driven car, such as mine. The difference in how smooth the car idles (even with a big cam) due too the Multi Spark Discharge, is hard to pass up. Plus you get the added integral adjustable Rev Limiter.
I mounted my 6AL under the dash and ran all wires to/from thru the dash so as to not have the box mounted visibly under the hood.
-Jay-
http://store.summitracing.com/defaul...ibuter&x=0&y=0
i have similar setup. only difference is i have the digital 6 plus box instead of the 6AL. more features and analog technology is getting dated. digital is more precise. box also has a spark retard on starup feature that helps with hot and cold starts, built in rev limiter dip switch so you don't have to buy the plug in "pills", a second stage rev limiter for launch rpm (if you decide to race it), and a nitrous retard feature. great unit
MSD offers "package" deals or you can buy the stuff individually and "mix and match" as you desire. there are a lot of options and ways to go. call MSD and get a catalog (915) 857-5200, also check out www.msdignition.com. they don't sell direct but Summit racing (and others) carry them. be sure to use parts that are compatible (ie. certain coils should be used with certain ignition boxes etc.). when people have problems with these things its usually because they didn't. remember the MSD is sending 500+ volts to the coil and stepping it up to about 50,000 whereas the stock HEI sends only 12 volts to the coil.
Distributor - 8361 - $189.88
Digital 6 box - 6520 - $279.88
Blaster II coil - 8202 - $29.88
Red wires - 35599 - $68.99
Total is $568.83
That is almost double your $300.00 limit and the only benifit I see over a MSD HEI is the rev limiter.
Pete
I have a new "Mallory Comp 9000" it's a Hi-Performance Billet Distributor with only about 500 miles on it! I can let you have it for $175 + shipping... if your interested. It cost me about $250 with tax and shipping when I bought it from "Jeg's"
It is my opinion that the MSD boxes are one of the best ignitions available today. I highly recommend them for all of the race motors I sell. But I also believe they are overkill on the street. You can get all of the benifits of the MSD boxes (except Rev limiter) in the MSD HEI distributor (provided you don't need tach drive) at a fraction of the price. Again, it is just a matter of how much money you want to spend. If your budget is $500+ for an ignition then I would say get the full system with a box. If your budget is $300.00 Then I would recommend the MSD HEI. Performance for his motor will be the same either way.
Pete
My car came with a brand new MSD 8572 and 6A. But with an automatic trans are u going to over-rev? Recently had my MSD 8572 curved and found it way off/slow - no full advance until 3600 rpm. So what i'm saying is that u could spend more money and still need to recurve the mech advance.
Good luck. cardo0
i am currently running this http://store.summitracing.com/defaul...rm+distributor
it has a 50,000 V coil and has been recurved as per Lars instructions...
it is just not an impressive piece...not made that well IMO...
i totaly agree that going full bore with a box and all is overkill for the kind of driving that i do...
yes, i DO bang gears and yes i DO put her thru her paces...
but i DO NOT race it in competition and probably never will...
to me, its just a fun little hot rod to own and drive...
as some of you have said...i doubt that i would ever feel the difference spending the extra $ and using "the box"...
my car starts great and idles great etc already...
i just want a higher quality replacement part than i am currntly running...
what i need is a high quality, 50,000 volt, no tach drive, "plug and play" dist for my car...period...
as a matter of fact...the Mallory that Intimidator454 has is probably just what i need...
or something like that...is this MSD comparable to it?
http://store.summitracing.com/defaul...h&Ntt=msd+8365
if so...should i buy his and save the extra $$$ ???
thanx for all of your help guys....its appreciated....
and whats all this about not needing vacumm advance?
ive been hearing that a lot lately...
i thought you need that...
whats up with that???
