I have to get new tires on my car and will most likely need a wheel alignment. I sure before even going in they are going to say they cannot do it because my bushings and such are dry cracked. So may question is what should i have to replace and how much should it cost?
I am looking to do mine this Winter and hoping to get away with it for about $150 in Parts ...
Get one of the Kits from Mid America or somewhere ....
Who has the best Kit for Bucks......
Just gonna use the car on the street ..No Autocrossing or anything like that ...
My mechanic quoted me somewhere in the neighborhood of $800.+ to rebuild my front suspension. It's something like $200 in parts, and $600.+ in labor because he'd rather have a root canal than take on the joy of rebuilding the suspension.
From: Arlington Va Current ride 04 vert, previous vettes: 69 vert, 77 resto mod
parts can be rubber or poly....i think mine were poly and were about $220 install was 700 and i had them re weld my lower pass side control arm mounting bracket to the frame....
VBP has a great front end rebuild kit has Everything you need it was $285 for the rubber. I did my own work but I did ask a shop and they quoted 14 hours at $50 an hour.
All the hard work was definitely worth it.
Vette Brakes & Products is THE source for suspension products. a lot of the stuff ecklers and mid-america sells is VBP stuff anyway. you just pay more by buying it from them.
a few years back i decided to have mine rebuilt with poly. bought the poly front bushing kit with tie rod ends, etc. think i paid several hundred dollars for it. went to a reputable shop. they made the mistake of quoting me a firm price of $600 to do the job. they got raped. they worked on it for about 2 1/2 weeks. old suspension parts can be a real bear to get off.
try to get a quote up front that they'll stick to. if they bill you by the hour don't be surprised if it comes out north of 1000 for labor. its a big job.
in 96 i paid $180 for a poly bushing rebuild kit from Zip(X-mas special), $90 for 2 460 springs from VBP, $25 to the machine shop for pressing old bushings out ,new bushings in, another $50 for 2 new shocks. basically, $350 and I did the rest of the work myself and it really was some of the easier work i've done on my vette
Question who makes the parts in these kits? Are they Moog,TRW, McQay -Norris, Chop Suey,etc I have had luck with them but also heard of wrong parts in kits on more then one order. I like Moog the best but they're also the most expensive. Had a NAPA brand lower ball joint wear out in 18k miles.
Gary
