Air compressor ?'s
Any suggestions?
My point being, it wil be hard to find something that will flow the CFM you'll need without having that 30 gal tank. If not, the compressor will run constantly, IF it can even keep up with the required airflow.
Any suggestions?
why not an electric impact hammer and a $90 pancake tank? and remember the impact hammer will ruin the chrome on the lugnuts
I went to it with my 1/2 drive air gun set for 105 # of TQ and it wouldn't move the lug nuts. I put a 1/2 breaker bar and stomped on it to get them loose enough.
I use a clicker wrench to set the nuts.
If all your doing is occasional tires you can't beat a 4 ended star wrench.
I have a 5 HP 60 Gal and 2 impacts and I do not use them for tires (on or off) I use a 1/2" breaker bar to remove and a click torque wrench when putting them on.As far as the compressor goes don't buy one until you have the tools you want to use, you have to match the compressor to the CFM rating of the tools.
Steve
......i meant a plug in one........
this all i use on any of my cars...................
MSRP on the 3-hp is over $2,200 but typical street/internet price is about $1,200.
Any suggestions?
Air tools can be VERY addictive. You may find yourself buying new tools and accessories uncontrollably.
Buy the best tools you can afford. There really IS a difference. Plastic or insulated handles are great to keep your hands from freezing and air outlet location can greatly improve the user experience. Don't underestimate the annoyance of the noise...of the compressor AND the tools. Some cheap tools can be VERY loud and irritating to use for any extended period. I like Ingersoll-Rand...
see any great harm in using it to remove any bolt or nut.
Yeah - chrome plated lug nuts might take a beating over time,
but they aren't too expensive.
BTW - my 12 gallon 4HP direct drive (noisy) compressor is very useful
for jobs here and there. If sandblasting or painting, you really gotta
step way up in capacity. Come on - it's not a NASCAR pit crew race.
Plus, the smaller compressor can be pumped up and wheeled out to
fill tires/etc. I don't think I'd want one that bolts to the floor.
A belt-driven oil-filled unit would be nice, though.
I have a high speed grinder motor (air compressor) powered. With a cut off wheel that thing is just like a torch when it comes to cutting metal.
I would think that someone with little experience with air tools could completely dissimble a C3 corvette in about 2 hours. (assuming no suspension corrosion.)
Anyhow... I bought my air compressor from Sears in the early 1970's. I just wish it would break so I could justify buying a bigger more powerful one. It's 240 volts, with a 30 gallon (?) tank. ...OK actually it satisfies all my present needs but I still would like a bigger one!
