Increasing HP
Old Dec 23, 2004 | 12:06 PM
markdtn's Avatar
markdtn
Tuned Port fuel injection on your stock bottom end and true dual exhaust.
Old Dec 23, 2004 | 12:08 PM
GrandSportC3's Avatar
GrandSportC3
Cruise-In IV-V-VI-VII-VIII Veteran
St. Jude Donor '03, '06, '17
Originally Posted by page62
The L82 cam isn't bad: .450/.460 lift with 222/222 duration. The same cam used in the '69 350ci/350hp engine. Do the heads before the cam...they're the weakest link!
no doubt about that.. Stock heads flow like crap... Unless you know how to port them yourself... it's a good idea to start with a good set of heads....
Old Dec 24, 2004 | 07:49 AM
Jason Staley's Avatar
Jason Staley
Cruise-In III Veteran
If you want some inexpensive light weight heads that flow decent, you could try the GM high output aluminum heads. They're the same ones that come on the ZZ4 engine and are based off of the L98 head casting. Nothing exotic, but decent light aluminum heads (have stock valve size).
Old Dec 24, 2004 | 07:59 AM
captainmorgan's Avatar
captainmorgan
Thanks Jason,
Do you know where I can get more info on these heads?
Is ther a website?
