Increasing HP
Old Dec 22, 2004 | 03:56 PM
captainmorgan's Avatar
captainmorgan
Default Increasing HP
What would need to be done to a stock 77' 350 L82 motor to get it to 300HP?
Old Dec 22, 2004 | 04:14 PM
page62's Avatar
page62
Desmogged, true dual exhaust, new heads, rebuilt & tuned carb. That should do it.
Old Dec 22, 2004 | 04:17 PM
bobs77vet's Avatar
bobs77vet
From: Arlington Va Current ride 04 vert, previous vettes: 69 vert, 77 resto mod
just add money............
Old Dec 22, 2004 | 04:21 PM
Gordonm's Avatar
Gordonm
Thats the truth. How fast you want to go is dependent on how much money you are willing to spend.
Headers cam and heads good intake and carb will put you at 300 to 350 HP.
Old Dec 22, 2004 | 06:58 PM
mandm1200's Avatar
mandm1200
[QUOTE=captainmorgan]What would need to be done to a stock 77' 350 L82 motor to get it to 300HP?[/QUOTE
You didn't mention where you wanted the 300HP, the crank or the wheels. The stock L-82 should be somewhere around 210HP with accessories and cat-exhaust. People tend to forget that horsepower was rated differently back in the old, old days. Although I do not have numbers, a 69 350HP would be much less if measured by todays standards.
The first thing is to get a performace exhaust system. That will get you perhaps the most bang for your buck. No matter what engine mods are done, this will have to be done so you might as well do it first. After that the next upgrade is normally cam and heads. If your target is 300HP or over, then you should be able to get away with changing the heads. The bad news is that heads will cost $500 on up while a cam/lifter kit can be purchased for well under $200. By doing the exhaust, cam, and heads the engine will be on par with the performace of the early C3 small blocks.
Old Dec 22, 2004 | 07:17 PM
GrandSportC3's Avatar
GrandSportC3
Cruise-In IV-V-VI-VII-VIII Veteran
St. Jude Donor '03, '06, '17
Exhaust, Heads and Cam
If you do the work yourself - it won't cost and arm and a leg and you can easily get up to 400 HP..
You can find World Product Torquer Heads fully assembled for less than $500.
Just add a nice cam with about .480 to .500 lift and 220 - 230 degrees .050 duration (probably $150 for the cam+lifters) and a true dual exhaust and you'll be in the high 300's for output ... and you won't spend too much over $1000 - $1200 for everything...
Old Dec 22, 2004 | 08:47 PM
captainmorgan
What brand of heads, cam and exhaust would you recommend.
Old Dec 22, 2004 | 09:01 PM
MYBAD79's Avatar
MYBAD79
St. Jude Donor '05
Well, I guess everybody would recommend what he/she has installed... I'm very happy with my Edelbrock setup: Performer series 64cc heads, cam, intake and carb.... runs great, very smooth idle, good throttle response and fast enough for now.... I will work on the bottom end next year and stroke it to 383 with forged pistons....
One more thing: I have the L48 with original 8.7 or so CR - your compression is higher than mine (I think 9.5) so you should see better HP numbers with these modifications..
Old Dec 22, 2004 | 11:29 PM
Bangkok Dean's Avatar
Bangkok Dean
I have the same Edelbrock set up with new bottom end around 9:1 compresion runs great.
Old Dec 22, 2004 | 11:45 PM
AlwaysWave's Avatar
AlwaysWave
Cruise-In III Veteran
and consider dropping some weight, fiberglass springs, aluminum engine stuff like waterpump, manifold, heads, tubular transmission crossmember, aluminum radiator etc.
Old Dec 23, 2004 | 12:30 AM
isosceles's Avatar
isosceles
don't do the rest without doing the heads. I warmed up an L48 with cam, headers, properly jetted too. The heads had to be the restriction as the car still turned 15's, just lower 15's Not to sure some compression wouldn't have helped too.
Old Dec 23, 2004 | 01:18 AM
BigBlockk's Avatar
BigBlockk
This kind of engine is screaming for a low to moderate boost single turbo system. You can pick up reman turbos on e-Bay for $250. The header companies sell "bends". That is, pre bent exhaust pipe sections for the runs to and from the turbo. Get some steel tubing for oil lines and you got it made. A setup like this would get you 350 to 400 HP and you would never know it was there until you hit the loud pedal.
I'll bet you could do the whole thing for $1000.
Hope this helps.
BigBlockk
Later.....
Old Dec 23, 2004 | 08:29 AM
captainmorgan
Hope this helps.
BigBlockk
Later.....
This sounds interesting but I do not know anything about what I would need for this setup. I would need detailed instructions and parts list.
Old Dec 23, 2004 | 08:34 AM
cmashark's Avatar
cmashark
77 L82's are 9to1 C/R with 76cc heads. if he puts 64cc heads on, he will be at 10.3to1 C/R. better make them aluminum so you can run the cheap gas.
chris
Old Dec 23, 2004 | 09:18 AM
MYBAD79's Avatar
MYBAD79
St. Jude Donor '05
chris
10.3 to 1 CR would be perfect, you should not have any problems with 91 or 93 octane pump gas... get some nice alu heads and a nice cam and you're set.... this should cost you around $1000 if you take your time and look for good deals...
Old Dec 23, 2004 | 09:31 AM
page62's Avatar
page62
The L82 cam isn't bad: .450/.460 lift with 222/222 duration. The same cam used in the '69 350ci/350hp engine. Do the heads before the cam...they're the weakest link!
Old Dec 23, 2004 | 09:36 AM
MYBAD79's Avatar
MYBAD79
St. Jude Donor '05
I agree, that cam isn't bad. You can do the cam later but it's not that expensive and you already have the engine apart when doing the heads... some heads require longer pushrods, you might want to to change the lifters and the cam at the same time.... anyway, the heads will be a huge improvement.
To Increasing HP
Old Dec 23, 2004 | 10:06 AM
captainmorgan
Where can I get more info on the "World Product Torquer Heads"?
Old Dec 23, 2004 | 10:20 AM
page62's Avatar
page62
There are all kinds of heads to choose from at Summit Racing or Jegs. Just add the "www." and ".com" to those names. I chose the Summit-brand heads for my swap (coming soon). Go to Summit Racing and search for SUM-152123
Old Dec 23, 2004 | 11:20 AM
TedH's Avatar
TedH
See my signature. Replace my heads/intake with Vortec pieces and you would achieve/surpass 300hp at the flywheel. With it, I'm at about 290hp.
