aluminum radiator??
Old Dec 23, 2004 | 06:07 PM
alglez's Avatar
alglez
Default aluminum radiator??
I found a aluminium radiator for a manual 73 radiator but my car is a 77 auto will it fit?
thanks
alfonso G.
Old Dec 23, 2004 | 07:34 PM
zwede's Avatar
zwede
It will fit but usually radiators for manual trannies do not have the built in tranny cooler so you would have to run an external cooler.
Edit: I need to add a disclaimer... I don't know for sure it will fit. The cooler thing I know though...
Old Dec 23, 2004 | 09:40 PM
markdtn's Avatar
markdtn
Pretty sure they are both 27 1/2" wide cores, but I agree with Zwede that you won't get a cooler for the trans with a stick radiator.
Old Dec 23, 2004 | 10:40 PM
Super Stock's Avatar
Super Stock
Call Tom Dewitt.
Old Dec 24, 2004 | 03:39 AM
hunt4cleanair's Avatar
hunt4cleanair
Corvettes were not equipped with aluminum radiators in 73...they all used the same unit which could be interchanged with auto or manual transmission. The GM# 3030199 got the call to serve both big block and small block from 1973-76 for LS4, L48 and L82 applications.
PS...these were brass copper units. The unit you found should have a metal tag on the passenger side with broadcast code, date code and part number...is it still present?
Old Dec 29, 2004 | 02:14 PM
Tom@Dewitt's Avatar
0Tom@Dewitt
Former Vendor
thanks
alfonso G.
The answer is NO. The 73 original, as pointed out was C/B, and it has a 27.5" core. The upper neck is 1.5" and curved 45 degree. The lower neck is 1.75"
The 77-82 radiator uses a 26.25" core, so it won't fit the core support. The upper neck is a 1.5" or 1.25" (depending on HP option) straight connection. The lower is a 1.5" connection.
Two totally different models, not to mention the missing trans cooler.
Old Dec 29, 2004 | 02:49 PM
Van Steel's Avatar
Van Steel
Premium Supporting Vendor
Get one of his aluminum rads. You won't be disappointed.
Old Dec 29, 2004 | 03:00 PM
Brettmc's Avatar
Brettmc
I got one and I wasn't...
Brett
To aluminum radiator??
