How to: Compression. oppinions?
Old Dec 24, 2004 | 08:12 PM
Glasspacked's Avatar
Glasspacked
Default How to: Compression. oppinions?
Was wondering , I would like 9.5-1 compression for my '73 350 project engine. Am I better off to #1, use flat top pistons & a set of 76cc heads, Or #2, Use the stock dished pistons & 68cc heads?
benefits or bad for either way? Oppinions/advise please.
Old Dec 24, 2004 | 08:27 PM
redwingvette's Avatar
redwingvette
When I rebuilt my engine I found that the deck height was almost 0.035" which means with the stock dish pistons and heads and 0.040 gasket, I was almost <8:1 instead of the advertized 8.5:1. I went with flattop pistons and 64cc heads just to get 9.6:1.
Old Dec 24, 2004 | 09:46 PM
stingr69's Avatar
stingr69
My opinion is you should check the condition of the bores and proceed based on that. If the bores are good enough for a re-ring job, you will be way ahead of you keep the stock pistons and buy some great flowing heads to get the compression up.
If the bores are trashed too far and need to go .030 oversize, you want flat tops and better heads to match the rest of the combo.
I just hate to see perfectly good parts going in the trash.
-Mark.
Old Dec 24, 2004 | 11:36 PM
hosspowerinc's Avatar
hosspowerinc
Flat tops are more resistant to pre-ignition. No hot spots.
Old Dec 25, 2004 | 12:56 PM
Glasspacked
Default research
It seems the more research I do, the more it looks like what is needed is a dome Piston (.100 dome) & 76 cc heads. gets it right to 9.5-1 .That way I don't have to buy BOTH pistons & heads. has anyone tried this approach?
Old Dec 25, 2004 | 06:43 PM
stingr69's Avatar
stingr69
Opinions are like belly buttons but in my opinion, those heads are absolutely the first thing to come out of the engine without a question. The bottom end and the rest of the top will support quite a lot of power as-is. Add some ARP rod bolts if you want cheap insurance. You can do a lot with the stock pieces without a lot of money but the heads are not worth their weight in cast iron. They do not flow well, they do not make enough compression, and they are crack prone.
SPEND MONEY ON THE HEADS is always a good rule when modifying an engine. Cam it to match the application and enjoy. Otherwise the heads will always be the limiting factor down the road.
-Mark.
Old Dec 25, 2004 | 11:55 PM
Glasspacked
Default cracking???
# 3973487 heads prone to cracking ?? I know #882 & #624 are known to be thin wall & prone to cracking, but never a bad word about 487. Have you experience with these?
Old Dec 26, 2004 | 08:01 PM
stingr69's Avatar
stingr69
I have not heard anything about cracking on those heads. They were the first lower compression heads used on LT-1's and lower HP motors in the early 70's but still heavy weight castings. If you are on a tight budjet or want to stay stock you could run them. Those are marginaly better than those late 70's smogger heads but not quite as good as the double hump heads used mostly in the 60's.
-Mark.
Old Dec 26, 2004 | 08:55 PM
Glasspacked
Default concidered the camel hump heads
I thought about the old "fuelie heads" but can't use them because of the lack of holes in the end of the heads. & the difference of $200 for a completely fresh set of 487s, & the price of Darts or aluminum puts them out of my budget. With those heads & the .100 dome pistons get it to 9.5-1 compression, (the pistons I've alredy got.)
Old Dec 27, 2004 | 09:01 PM
stingr69's Avatar
stingr69
"186" Fuelie heads have the holes in the ends but those are a little harder to get. I have them on my Camaro. "041" heads are the same as "186" heads but they do not have the double humps so they sell for less. Just a little thing to keep in mind when looking around at swap meets.
Either way, it sounds like you have a good plan.
-Mark.
Old Dec 27, 2004 | 09:39 PM
Glasspacked
Default Very interesting.
I've seen quite a few pairs on ebay lately. I'll check em out.
Old Jan 6, 2005 | 08:25 PM
Glasspacked
Default Don't buy heads on ebay
I bought a set of supposedly 487s on ebay. what I got was 1- 487 & 1- 993. the 993 has a crack from the center bolt hole up between the 2 center cyls., 4 sunken valves, 35 year old valve springs,& cast grey paint over grease. (These were advertised as totally recond., 3 angle,.550 LIFT new springs, ready to bolt on) I called the vender, Shawn Anderson of "southern Cylinder heads" 256-535-4403 (using sda316as a seller name) in Alabama to see about getting replacements, & was pretty much told to f- off. & I was stuck with them. so, if you are thinking of buying heads on the internet, BEWARE.
Old Jan 6, 2005 | 08:42 PM
MYBAD79's Avatar
MYBAD79
St. Jude Donor '05
If you buy on Ebay you have to check the seller's feedback - there are many great ebay stores, there are many a$$holes out there....
You really have to take the time to go to their feedback page and see what they sold .. some sellers never sold anything but got a lot of good feedback for buying cheap stuff on ebay, then when the feedback rating is good they try to sell their junk....
There are sellers that have 10000++ feedbacks and 100% positive....
this seller sda316 has only 29 feedbacks
Old Jan 6, 2005 | 09:12 PM
Glasspacked
Default fufurther inspection
Looking even more closely, On one head there are valve rotators on the exaust & none on the other head! never heard of a "small block with valve rotators, (& then ,only on 1 head) I did look at his feedback. was all good.
To How to: Compression. oppinions?
