Two holes or three?
Old Dec 24, 2004 | 08:35 PM
74FLCONV's Avatar
74FLCONV
Default Two holes or three?
Looking for a set of new (aluminum) valve covers. Most examples come with two holes. My stock covers have three (filler, PCV, breather-to-air filter).
Will the PCV or breather hole double as the filler hole?
D. Ocean
Miami, FLA
Old Dec 24, 2004 | 08:54 PM
markdtn's Avatar
markdtn
You want to be sure the PCV has a baffle behind it, otherwise you will have oil consumption problems.
Old Dec 24, 2004 | 09:11 PM
74FLCONV's Avatar
74FLCONV
Most of the valve covers come with baffles. But where do I fill if both openings are baffled?
D. Ocean
Miami, FLA
Old Dec 24, 2004 | 09:16 PM
Double Aught's Avatar
Double Aught
Merry Christmas, everyone!
Old Dec 25, 2004 | 12:31 AM
randy814u's Avatar
randy814u
You can fill through a baffled hole. I just put down two quarts through one side, then went over to the other side and dumped two quarts, and no problems.
Old Dec 25, 2004 | 05:28 AM
guppie's Avatar
guppie
St. Jude Donor '08
The set I just bought from Corvette Central has all 3 holes.
Old Dec 25, 2004 | 07:45 AM
norvalwilhelm's Avatar
norvalwilhelm
I like the 2 holes. One for the pvc and one for the breather. I don't like the push in breathers and prefer a line from the air cleaner. It keeps the motor cleaner, push in breathers can become messy with oil fumes.
Old Dec 25, 2004 | 05:55 PM
markdtn's Avatar
markdtn
I understand now, I thought you meant 3 holes per cover. Yes, either 2 or 3 will work. You can fill and vent through 1 and PCV in the other or have 1 for fill, 1 vent, and 1 PCV. Norval is correct that the unit vent/fill caps do tend to ooze a bit and make your engine dirty.
To Two holes or three?
