When I install my GM/T56 Viper trans, I want to use a pilot roller bearing.
Does this one fit my 68 427 CI BB M21 setup ? The T56 Viper should have the same size as the M21.
SUM-G1700 Roller Pilot Bearing, Chevy all V8, 90 Degree V6, 76-up Buick V6
$12.99
I agree with Budman...roller bearings flatten out, where Bronze bushing just wears eventually over time, however, its better in the long run to go this route, over the a roller bearing.
I was looking into this a time ago and searched the archives and the conclusion was that if you`re going with a roller bearing you have to check the alignment of the inputshaft vs crank. ..
Our Nascar engines use either a bushing or bearing, it is up to the team.
Either the bushing or bearing only comes into play when the clutch is disengaged. Then the input shaft and the crankshaft spin at different speed. When the clutch is engaged both the input shaft and the crankshaft spin at the same RPM so it does not matter whether you use a bearing or bushing. Shifting is not an important matter for Nascar motors except at Pocono or the road coarses.
If you are flattening out roller pilot bearings you either have an alignment problem or have a low quality bearing(a lot of aftermarket pilot bearings are very low quality). Whenever I use a pilot bearing I only use one from GM. But personally I do not see a benifit of one over the other.
Regardless of which one you use, if you shift hard make sure you dial indicate the bellhousing to eliminate any bind.
Any P/N for this, so that my fellow worker collegue can get it from Chevy for me ?
@ redvetracr
Thanks for the offer. Asking my collegue will save me the shipping and you the hassle. I would need the P/N to make it easy for him.
He lives in Seattle and drives " Mercedes ".
From: Who says "Nothing is impossible" ? I've been doing nothing for years.
Annone here know how to get the old bearing out with the motor in the car, heard a couple of ways that sound more like someone just thought up a way that might work including the grease gun fantasy I had to hammer mine in so I doubt it will come out easy, anyone actually done it ?
I've always just heard that you blob grease into the hole in the bearing, and find a rod thats the same size as the ID of the hold in the bearing. Push on grease, grease pushes bearing out.
I've never been able to "hydraulic" one out with the grease and toilet paper trick. Try a small slide hammer and see if you can tap it out. If that fails, use a die grinder/dremel and cut radial cuts in it and take it out in pieces. DON'T get overzealous with the die grinder and gouge your crank. Chuck
Yes I have numerous times. I use a wooden dowel that is close to the same size as the bushing ID, the closer the better. Some masking tape wrapped around the dowell works to tighten up the fit if it is a little loose. You fill the cavity with chassis grease and then use a hammer and the dowell as a piston on the grease to force the bushing out. Rap it hard and check your progress as you go. You will want an old t-shirt wrapped around your dowell close to the bushing as the grease will squirt out a bit as you work. You will probably need to repack the cavity once or twice as you go if you hit bottom (back of crank) with the dowell. It can be messy but it is effective. Hard to believe if you have never seen it before but it works.
