Quick question
Old Dec 27, 2004 | 01:23 AM
Guru_4_hire's Avatar
Guru_4_hire
Cruise-In IV Veteran
Cruise-In V Veteran
Default Quick question
I am in Korea with the army right now. The 73 is chillin in a barn in NY.
Can someone tell me how far it is from the air cleaner too the radiator?
Old Dec 27, 2004 | 10:59 AM
raider21's Avatar
raider21
I'm no mechanic, but I am pretty handy with a tape measure and should be able to help you with this but will need more info.
1. From where on the air cleaner to where on the radiator?
2. In inches or cm?
3. Never heard this question before, what are you thinkin?
Oscar
Old Dec 27, 2004 | 11:16 AM
OHSIXX's Avatar
OHSIXX
C2 of Year Finalist (performance mods) 2019
Anything for an Army Guy!
From the center of the air cleaner on my 72 SB to the rear of the radiator is approximately 21 inches.
From the leading edge of the 14" air cleaner to the radiator is approximately 14 inches. See pic below.
Old Dec 27, 2004 | 11:28 AM
joe73vette's Avatar
joe73vette
15" from the front of the air filter can to the back of the radiator support.
9 1/4" from the front of the air filter can to the shroud.
This is on my 73 with an L48 small block and the factory air filter. Joe
PS here's a picture:
Old Dec 27, 2004 | 05:50 PM
Guru_4_hire
Cruise-In V Veteran
So about 15 inches. Perfect.
I have a pair of grand national turbos, and a pair of carbuerators from a turbo esprite.
I am thing of moving the radiator forward as far as I can and mounting the intercooler paralell to the hood. between the carbs and the radiator. The turbos are going to mounted low in front of the front crossmember and the pullies.
Probably gonna modify a hood to direct the high pressure air from underneath the car through the intercooler and out of the hood like the C5R does.
Old Dec 27, 2004 | 06:15 PM
joe73vette's Avatar
joe73vette
Finally, a use for the fake holes in a stock 68-72 big block hood. Sounds like a cool project.
Joe
To Quick question
