Critical piston question
Old Dec 27, 2004 | 02:03 AM
Jclgodale3's Avatar
Jclgodale3
Default Critical piston question
While tearing down my 350 for a top end rebuild I found a small ear off one of the bottoms of the pistons where it appears it came off during assembly. The motor was strong before disassembly before tearing it down with no noise and compression in all cylinders were consistant.
The motor was stated as having roughly 10,000 miles on it when I purchased it. My question is "what if anything will this affect"? Balance? There is no indication of any scoring of the cylinder wall in which it came from. Any help or suggestions would be appreciated. Major concern? Minor concern? No concern?
Old Dec 27, 2004 | 09:17 AM
Michel B's Avatar
Michel B
From: Ville de la Baie Quebec. A winner is just a loser who tried again.
The local performance machine shop here, balances pistons to within 4 grams. So if you can guestemate the weight of the missing peice to be within this range,, I don't think it be a problem.
Old Dec 27, 2004 | 09:29 AM
bobs77vet's Avatar
bobs77vet
From: Arlington Va Current ride 04 vert, previous vettes: 69 vert, 77 resto mod
why not take it to a machne shop and get their opinion....can you post a picture of it? some of the lower piston skirt area is used to stop the piston from rocking in the cylinders...its hard to tell you anything definitely with out pictures......but if it was running well before hand and there is no scoring i would say these are positive signs...
Old Dec 27, 2004 | 01:05 PM
Jclgodale3's Avatar
Jclgodale3
I have a picture ready but I am not allowed to post attachments?
Old Dec 27, 2004 | 01:18 PM
Jclgodale3's Avatar
Jclgodale3
added it to my photo's if you don't mind taking a look?
Old Dec 27, 2004 | 02:33 PM
L71Maynard's Avatar
L71Maynard
I looked in your photo section but don't see that particular picture.
Dave
Old Dec 27, 2004 | 02:34 PM
bobs77vet's Avatar
bobs77vet
can't find it ....can you see it in your gallery?
Old Dec 27, 2004 | 03:41 PM
Jclgodale3's Avatar
Jclgodale3
let's see...can't post attachment pictures to my threads and when I post one to my Gallery...they "pend it" for a good 8 hours before posting it...getting frusterated...
Old Dec 27, 2004 | 06:48 PM
Jclgodale3's Avatar
Jclgodale3
ok...the pic is finally in my photo gallery if someone could take a look at the size of the peice that is broke off...thanks
Old Dec 27, 2004 | 06:54 PM
joe73vette's Avatar
joe73vette
Where did you find the piece, in the oil pan? Is it a cast or forged piston? Are you sure it has been off since assembly? They are there to keep the piston from rocking, and the cylinder should have weird wear marks on it if it was missing for long. .
BTW, I dropped one of my pistons when tearing it down for new bearings, and broke the same piece off. The machine shop that did the rods got me a replacement for not much money.
Joe
Old Dec 27, 2004 | 07:37 PM
MotorHead's Avatar
MotorHead
From: Who says "Nothing is impossible" ? I've been doing nothing for years.
NOt sure what to do there maybe talk to a machine shop about it, possibley if you know what the part number of that piston is you could replace it re-using the broken in rings. Any half decnet piston set is weight matched these days so the wieght would probably be OK if it was the same part number. Not sure but that piston could damage the cylinder so you have to tear it down anyway and it could even gouge it meaning a new block
Old Dec 27, 2004 | 07:43 PM
bobs77vet's Avatar
bobs77vet
thats pretty big.........it looks like it is the part of the piston skirt that stops the rocking motion....if you want my opinion i'd say that piston is toast.........i could not justify putting that back in.... a picture of the piston would confirm my thoughts... sorry...i know you are having difficulites posting them....
Old Dec 27, 2004 | 10:12 PM
Michel B's Avatar
Michel B
You know,, I broke a peice off one of my pistons by hammering them out with a wooden dowel, and before anybody says that I must have hammered the crap out of it,,,(I didn't). they are suprisingly delicate. You know, I think we are all alike in the sense that we want to save a few bucks when we can,, and thats ok, but for the price of a new set of pistons (stock),, I think it would be wize to change them. Once the motor is all back together and in the car, you will hate yourself if it develops a vibration...
Old Dec 27, 2004 | 10:18 PM
jlch's Avatar
jlch
My vote would be fix it. You already have it apart so it's no big deal. It would suck to put it back together and have a vibration or worse have it shatter the piston down the road and ruin the crank/block/heads/cam/etc. Who knows what the rest of the piston looks like or if it has any cracks in it that you may not be able to see with the naked eye from underneath looking up. A few dollars is cheap insurance and piece of mind.
Old Dec 28, 2004 | 12:47 AM
Jclgodale3's Avatar
Jclgodale3
so the overall concensus is to fix it so...should I just replace the one piston and re-use the rings? Thanks for all the help!
To Critical piston question
