DYNO Graphs - Post'em!!
Old Dec 26, 2004 | 10:13 PM
yellow68's Avatar
yellow68
Default DYNO Graphs - Post'em!!
O.K.,
Looking for dyno graphs and a quick description of your mods.
Also, it would be GREAT to see some motor dyno's backed up with what your ended up with on a Chasis dyno.
I know we have some crazy HP cars here.....let's see those dynos!!
Bryan
Old Dec 26, 2004 | 10:16 PM
GrandSportC3's Avatar
GrandSportC3
Cruise-In IV-V-VI-VII-VIII Veteran
St. Jude Donor '03, '06, '17
I don't have the engine anymore.. but here's the dyno sheet (REAR WHEEL HORSEPOWER)
383 stroker engine with custom solid cam (flat tapped) .525/.540 lift and 238/248 degrees duration, Dart Iron Eagle 215 cc heads (ported) and Edelbrock TM-1 intake with 1/2 inch spacer. 1.5 Ratio Roller Rockers, 10:1 compression, Holley 80528 racing carb (mech. secondaries double pumper HP series 750 cfm)...
Old Dec 26, 2004 | 10:19 PM
yellow68's Avatar
yellow68
That's a heck of a torque curve! Thanks for sharing.
I can't make out the AF ratio you have there. What were you tuning for?
Bryan
Old Dec 26, 2004 | 10:23 PM
GrandSportC3
Bryan
The A/F was way too lean at high RPM's.. somewhere around 14 - 15
It might have had something to do with a clogged fuel filter...
The guy that bought the engine found out that the stone filter caused lack of fuel...
Old Dec 26, 2004 | 10:42 PM
MotorHead's Avatar
MotorHead
From: Who says "Nothing is impossible" ? I've been doing nothing for years.
Here's mine with a full exhaust system and mufflers I would expect a huge increase when i get my Hooker sidepipes on and run them open like GSC3.
I kust did one pull for fun with no tuning I shut it down at 5 grand to because I already blew a few gears out of the original Sper T10 with this motor
I don't know where the HP is going to go in the spring when I take it to 6500 RPM with a new TKO 600, Hooker sidemounts, tuning and Holley 950HP carb but I am pretty sure it will be well north of 400RWHP
Old Dec 26, 2004 | 10:49 PM
GrandSportC3
You should be well in the 400 - 420 RWHP range with your setup..
Old Dec 26, 2004 | 10:54 PM
MotorHead's Avatar
MotorHead
And we will be waiting for the numbers on the new AR 406
Old Dec 26, 2004 | 10:59 PM
GrandSportC3
I can't wait to get it.. It is built.. but it's taking time to finish dyno tuning it..
Old Dec 27, 2004 | 12:02 PM
GrandSportC3
Only 2 people with dyno sheets on the forum
Old Dec 27, 2004 | 12:09 PM
zwede's Avatar
zwede
Dyno graph, Rear wheel power.
Red curve: dyno after I got the car (mostly stock).
Blue curve: All mods in sig except crappy intake and carburetor. No dyno with EFI yet.
Old Dec 27, 2004 | 01:35 PM
yellow68's Avatar
yellow68
Another fine graph. Did you ever have your new buildup on an engine dyno?
There should be some excellent cold weather there in Plano right about now; might not be bad timing for some EFI tuning. **Thanks again for sending me your Holley 950 MAPS**.
Bryan
Old Dec 27, 2004 | 01:45 PM
ML67's Avatar
ML67
Rear wheel numbers:
Old Dec 27, 2004 | 01:58 PM
yellow68's Avatar
yellow68
WOW!!
That really is unbelievable!! That thing must really feel like a rocket!
I would love to get a few more specs on your car. Do you happen to have a webpage?
Very, very impressive my man!
Bryan
Old Dec 27, 2004 | 07:06 PM
toddalin's Avatar
toddalin
This is a real street engine with original heads that could live life as a daily driver, but for some reason, my dyno numbers come out about 40-70 hp more than bigger the ZZ3s and ZZ4s.
331 CI, pump-friendly 9.5:1 CR
K&N 14"x4" air filter, Corvette drop base and lid
Holley 600 dp, choke horn milled, polished
1/2" Aluminum open spacer port matched to manifold, exterior polished
Edelbrock Performer RPM, port matched, exterior polished with all extraneous castings and lettering removed
Homemade lifter valley splash shield to keep hot oil off manifold bottom
Camel hump 1.94/1.50 heads hogged out to 2.02/1.60, pocket ported, port matched, pump-friendly hardened seats, 3-angle valve job
Comp Cams 1.52:1 roller-tip rockers
Crane Cam Vintage Muscle 327/350 hp cam, 222 degrees @ 0.05", 0.447" lift (with 1.50 rockers)
Doug Thorley headers, dechromed and ceramic-coated
2.5" mandral-bent exhaust (including tips), 2" cross-over just before rear axle
DynoMax stainless Ultra Flow mufflers
Mallory Hyfire IV CD ignition box triggered off Accel points
Mallory high voltage chrome coil
Mallory spiral-wound coil wire
Mallory solid copper plug wires, ends soldered to wires
Champion plugs
37 degrees total ignition advance
Carter high-volume fuel pump
Melling high volume oil pump
Open breathers
Polished aluminum high flow water pump
Flex fan with polished aluminum spacer
Polished aluminum one-wire 100 amp alternator
Muncie M-20 CR 4-speed
Hurst shifter
3.70:1 positraction
225/60/15 Firestone Firehawk SZ50s on 7”-wide Western 30-spoke Turbine Wheels
Engine has never been professionally tuned up. Car recently did 293 ft-lb and 292.7 hp @ 5,500 rpm at the wheels on the chassis dyno. Engine pulls to 6,200 rpm and does over 200 ft-lb from 1,900 rpm. This was prior to some clean-up work around the junction of the carburetor and base of the air cleaner that smooths the flow through this area and should be good for a few ponies. Car has run 107 mph in the high 13's (old, bad tires) at the quarter. Car is extremely streetable and could probably even run 87 octane if it had to. (I can't get the engine to ping no matter how far I advance the ignition.)
I've just done some modifications in the area of the carburetor/air cleaner base interface that substantially smooths the flow through this area. When Lars comes next month and tunes this thing up, I would expect at least 300+ hp at the wheels.
The secret to power is in the attention to details!
Old Dec 27, 2004 | 07:16 PM
Corz's Avatar
Corz
Cruise-In IV Veteran
I'll have to scan it in, but its not that impressive
Old Dec 27, 2004 | 08:12 PM
ML67's Avatar
ML67
Thanks Bryan. It does merge into traffic well. No 1/4 mile numbers yet, but I put over 3K miles on it this past summer. Next spring I will.
548" Mark IV Bow Tie block
11.2:1 CR
AFR 335 CNC heads
ported Vic Jr intake (Bernard Mondello)
Carb Shop Holley 4150 HP 1000 carb
Comp solid roller 266/272 @ .050
2 1/8" headers 3 1/2" exhaust w/ Borla XR-1 mufflers
Richmond Gear 5 speed by G-Force
3.08 1350 Tom's IRS
There are 2 other forum members I know w/ very serious pump gas engines. Jim Moore (427Hotrod) has a healthy 540" in his 67 convertible that runs 10.0 @ 140 on pump gas. You may have seen it on the cover of Feb Corvette Enthusiast. I'm guessing he puts out about 700 RWHP. Steve Barker (632C2) has a 632" Big Chief stuffed in his 67 coupe. He spins the Dynojet at over 900 RWHP w/ a deceptively stock factory appearence (well except for his 'stingersaurus' hood scoop). And another forum member, 69 N.O.X RATT, has recently purchased a 63 drag Vette that he's targeting over 1400HP w/ nitrous. And he's going to drive it on the street! Some serious C2's lurking around here!
Take care,
Mark
Old Dec 27, 2004 | 09:45 PM
bobs77vet's Avatar
bobs77vet
From: Arlington Va Current ride 04 vert, previous vettes: 69 vert, 77 resto mod
this is a reality check for you stock L48 guys ...this is a 126 k, 77
L 48, no smog stuff, headers, 2 into 1 exhaust with cats....
best run 142 rear wheel hp, 235 ft lbs
[IMG][/IMG]
Old Dec 28, 2004 | 12:22 AM
tsw71's Avatar
tsw71
Here's mine. Not exactly wild, but good enough for now.
Stock 2 bolt block .030" over/cast crank
TRW forged flat top pistons with 4valve reliefs
10.4:1 CR with steel shim gaskets
out of the box Trick flow 23deg heads(64cc,no porting or cc work)
Comp cams 282S (solid)
comp cams 1.52 roller tip rockers
Weiand 7525 Team G single plane
Holley 650dp
hooker comp headers(1-5/8")
custom mandrel bent 2-1/2" exhaust
dynomax ultraflows
Mallory unilite w/MSD blaster coil
Old Dec 28, 2004 | 12:59 AM
Z-man's Avatar
Z-man
Not a graph, but the dyno results are printed...
http://forums.corvetteforum.com/show...5&page=2&pp=20
To DYNO Graphs - Post'em!!
