Lighting issues. Plz Help
Old Dec 27, 2004 | 03:09 AM
EVIL_GRIM's Avatar
EVIL_GRIM
Default Lighting issues. Plz Help
i got a 79 vette with serious lighting issues. basically when i installed a new headlight switch, the high beams would turn on (they are stuck on) but the low beams wouldnt even work. then a few days ago when i had the tranny rebuilt the exterioir lights stopped working except for the headlights. then my interioir would work when i hit the brake with the car off....In Short....
WHERE IS THE GROUD FOR THE LIGHTS?
is it somewhere on the outside, or is it inside the car? i think i may have moved something causing it to have a short, or i just have a really rusty conenction on the ground casuing it to go intermintent.
Old Jan 2, 2005 | 12:40 AM
EVIL_GRIM's Avatar
EVIL_GRIM
Still Cant find the ground for the lighting system in my 79'. i have a bad leak coming from the driver side somewhere and its running into the cockpit and shorting something out where the ground is i think.
Old Jan 2, 2005 | 01:06 AM
RHD '68 L89's Avatar
RHD '68 L89
First place to check is the chassis next to the battery. this where all the current in the car flows back to the battery. the cable comes out of the battery box and terminates on the chassis. This is underneath the car.
Next check the ground at the engine. The cable goes from the chassis at the engine mount to the block and is usually held on to the block with one of the engine mount bolts.
There is a ground which comes off the starter mounting bolts and feeds into the loom. On the 68 this feed is for the wiper motor and blower only.
The headlights ground is usually bolted to the front of the radiator support panel.
the rear lights ground is bolted to the chassis on the (drivers?) side.
Make sure all of these are clean and make good contact.
Hope this helps.
Old Jan 2, 2005 | 03:33 AM
cchristo's Avatar
cchristo
When I got mine, it looked like a rats nest under the dash. Serious "bubba" wiring fixes had been performed. The wiper switch was bad, so it had been bypassed. The stereo was some cheapo aftermarket that had been grafted into the wiring with complete disregard for anything.
It was a mess, and there were countless electical gremlins.
I ordered a wiring diagram and started going through one system at a time.
It was a real PITA, but it all works now.
The wiring diagram is a great investment and will save you a lot of time and grief in the long run.
Good luck.
Old Jan 2, 2005 | 09:07 AM
EDDIEJ82's Avatar
EDDIEJ82
Maybe this will help
http://iotech.no/corvette/technical/...tics/index.htm
Old Jan 2, 2005 | 01:35 PM
Paul L's Avatar
Paul L
Here is the wiring diagram for the 1979 headlight circuit. The grounds for the lights are at the front of the car. The "fender support" is actually the rad support.
http://img.photobucket.com/albums/v1...circuit004.jpg
Old Jan 2, 2005 | 01:40 PM
Aflac's Avatar
Aflac
Cruise-In 5, 6 & 10 Veteran
St. Jude Donor '09
I had a similar problem and it was corrosion on the fuse panel it self. I went to NAPA to get some fast drying electrical contact cleaner and toook the screws out of the panel and sprayed the back of it... put it back in and sprayed the front side... works fine now...
Old Jan 2, 2005 | 01:44 PM
toyvet1's Avatar
toyvet1
My 79 four speed has a ground wire going to the bellhousing on the passenger side. It was left off and I had problems with heater, wipers and lighting...
Old Jan 3, 2005 | 02:46 AM
EVIL_GRIM's Avatar
EVIL_GRIM
what book did you get that wire diagram out of, whats the name of it and where can i get one for a 79? i want that book!
Old Jan 3, 2005 | 02:48 AM
EVIL_GRIM's Avatar
EVIL_GRIM
was the number of the contact cleaner like a CRC 091343? LOL i would know nothing about that stuff. i only work there. jeez why didnt i think of that, oh byt he way where are the screws for the fuse panel?
Old Jan 3, 2005 | 06:17 AM
Aflac's Avatar
Aflac
St. Jude Donor '09
That sounds pretty familiar for the P/N... The screws are in the corners and they can be a royal pain to get started while standing on your head! I think if I have to do that again, i'm gonna pull the speedo out and go at it that way...
Old Jan 3, 2005 | 07:53 AM
Paul L's Avatar
Paul L
The diagram is one of many in the factory service manual.
www.helminc.com
Old Jan 5, 2005 | 12:48 AM
EVIL_GRIM's Avatar
EVIL_GRIM
is it the Service and Ownder Information one? i just dont wanna spend 60 bucks on the wrong book.
Old Jan 5, 2005 | 01:19 AM
RHD '68 L89
Grim,
You want the shop (service) manual as pictured above or the Assembly manual.
The service manual tells you how to repair things including the specifications and the Assembly manual tells you how they (were supposed to) put it together at the factory. Both will have the electrical diagrams.
The Service and Owner manual sounds like the little book the original owner received with the car telling them how to operate it.
Old Jan 5, 2005 | 01:55 AM
EVIL_GRIM's Avatar
EVIL_GRIM
i already got the assmebly manual, and its ok, but it doesnt show Exactly where the grounds and electrical components are which is what i want.
Old Jan 6, 2005 | 03:05 PM
EVIL_GRIM's Avatar
EVIL_GRIM
So does anyone know exactly where the ground is for the interior lights? and how do you get to it cuz i wanna have lights at night.
Old Jan 6, 2005 | 04:39 PM
RHD '68 L89
Interior lights or dash lights?
The interior lights have a permanent volts applied and switch the earth at the door jamb switches. The interior switch on the light switch also switches earth.
The dash lights are fed volts via the resistor on the light switch (maybe different on later models). the instrument clusters have a ground wire attached and this ground is commoned before being attached to the birdcage. On my 68 the attachment point is on the hinge pillar on the drivers side. This is up behind the dash.
If you have no dash lights I would check the resistor in the light switch first. They have a tendency to go open circuit. If everything else is working (clock etc..) then the ground is there.
Old Jan 9, 2005 | 12:55 AM
EVIL_GRIM's Avatar
EVIL_GRIM
i replaced the headlamp switch recently and then nothing worked still (dash lights, exterior excluding headlights) and out of the blue the interior lights started working on a cold wet night and it was a miracle, and now they dont work again, so im guessing the ground is very ad and has lots of rust. would it be suitable to find a better place to ground everything so i dont have to worry about moisture and leaks getting onto the ground?
To Lighting issues. Plz Help
