Interior identification with 1973
Old Dec 27, 2004 | 03:57 PM
Mike Mercury's Avatar
Mike Mercury
Default Interior identification with 1973
although my wifes 1973 was supposed to ba all original (not all that important with a small block C3)... I do think some of the interior parts are from mixed years.
here are two pics and I'll then point out what I think are amiss. Would appreciate any comment and info.
the cars trim code tag states a white exterior with Oxblood interior - and that's what we basically have,
In the first pic, the map pocket panel is a lot brighter red than the console. A person told my wife that even from the factory these interior pieces colors rarely matched - but there is quite a difference between some pieces on her 1973.
The dash pad matches the map panel more than the speedo/tach panel. The tach/speedo surround is a darker red than the upper dash panel.
And then there's the seats. Are these 1973 seats??? They do not have the holes for sholder belts; could a 1973 been built with these seats???
And these seats are again a lighter red then I think they should be.
Door panels - they seem a lot brighter red than the center console and they do nto have a woodgrained insert. Could the 1973 be ordered with these door panels?
Thanks for any help offered.
Old Dec 27, 2004 | 04:06 PM
bobs77vet's Avatar
bobs77vet
From: Arlington Va Current ride 04 vert, previous vettes: 69 vert, 77 resto mod
as to color....none of my red interior colors match up very well with the other colors....of course who knows whats original and not....however it is surprising how well it looks all together though....
Old Dec 27, 2004 | 04:24 PM
NHvette's Avatar
NHvette
Your seat covers look to be aftermarket replacements.
Original seats were stitched horizontally - like your center console pad.
You should be able to tell from the trim tag codes whether
the car came with deluxe interior (leather seats and wood door panel inserts).
My book calls your interior "Dark Red" (425). It only came in vinyl.
No red leather seats between 69 and 75.
In order to get it all matching, you might need to take it all
apart and dye it all with the same dye.
Old Dec 27, 2004 | 04:40 PM
checklst's Avatar
checklst
The big one is the radio of course. The carpet looks to be cut pile deluxe carpet so it an off match to the door panels(one or the other needs to change) as for the color oxford match, most did not match when new, GM just took what the suppliers gave and figured we did not care.
The screw on the passenger dash panel top should be SS or chrome and the Hair clip on the e-brake was not standard or a vary rare option!!!LOL
Old Dec 27, 2004 | 04:47 PM
Mike Ward's Avatar
Mike Ward
If your trim tag shows 425, that indicates a dark red standard vinyl interior. Leather seats/deluxe interior was not available in that colour for 1973.
That means that you should not have cut pile carpeting on the floor, no carpeting at the bottom of the door panels and no wood trim on the doors or center console. Also means that the seat covers should be vinyl, not leather.
The seat cover pattern you presently have does not appear to be from '73, and all coupes had shoulder belts that went throught the seat back. Only convertibles were available without shoulder belts.
Hope this helps.
Old Dec 27, 2004 | 04:56 PM
Roscoe's Avatar
Roscoe
looking and I agree with Mike & NHvett.
Is it NCRS ? I say that in a nice way
shoulder belts were std. with coupes but I think they were an option.
Old Dec 27, 2004 | 05:01 PM
joe73vette's Avatar
joe73vette
This is what a 73 seat looks like without the seat belt. Yours are not original. As Mike Ward said, only convertibles came without shoulder belts that year. The pleats go horizontally for leather seats and vertically for vinyl seats. Joe
Old Dec 27, 2004 | 08:10 PM
Mike Mercury
what can I say... you guyz are GREAT !!!
and I should of mentioned - we put in new carpeting and did not go with the NCRS correct pattern - the wife picked the style she liked best. Momma gets what she wants
Old Dec 27, 2004 | 08:16 PM
Paul Borowski's Avatar
Paul Borowski
Cruise-In VI Veteran
St. Jude Donor '08-'09-'10-'11-'12
The seats appear to be of the '76 vinyl type with no metal bar in the top of the seat and with the "vertical" seam pattern. They are not the '69-'75 vinyl "comfort weave" style.
Old Dec 27, 2004 | 08:18 PM
Mike Mercury
Oh, the two numbers on the tag are "425" and 910"
so does the 425 mean vinyl - and at least are the door panels correctly trimmed ???
Old Dec 27, 2004 | 08:21 PM
Mike Mercury
Paul; I was kinda leaning that way on the color (but not necessarily from the seam design). A friend of mine has a low mileage 1977 with the original red interior. Compared to the true oxblood colors... his is much brighter red.
But his car is in storage so I can't confirm everything (my memory is failing).
Old Dec 27, 2004 | 08:22 PM
Paul Borowski
The door panels look right-they'd have the carpet on the bottom below a chrome strip like joe73vette's door panel if they were "deluxe" door panels. The seats might even be "original" with just '76 style vinyl covers on them.
The '73-'75 "oxblood" colors were a "darker" red than the '76 & '77 red interiors.
Old Dec 27, 2004 | 08:26 PM
73jst4fun's Avatar
73jst4fun
Mike, the seat covers/seats look like they have been replaced, standard interior was comfortweave, missing the trim for the shoulder belts to pass through, the color should match your side quarter panels, also is that an a/c car?, the photo shows your missing the small trim piece that is on the passengers side that hides the support bar for the dash... hope this helps
Old Dec 27, 2004 | 08:30 PM
Mike Mercury
so the car did not have the "deluxe" interior trim. The door panels may look properly trimmed (ot lacking thereof) but the color is so much brighter than the center console that I'm not so certain they're oxblood color or not.
My digital camera made the color differences more pronounced. Most people - when looking at the car - don't notice it until I point it out.
If my wife decides on driving it to the Cruise-In, some of you can take a better look at it.
The main thing is that the wife is very happy with the car and not complaining at all. I just like knowing exactly where it stands... in the proper scheme of things (year wise).
BTW; it's an L82
Old Dec 27, 2004 | 10:34 PM
Mike Mercury
yep
and yep
Found a flea-market booth at Carlisle this year that had that picece and one other AC duct that was missing. I didn't buy it when I found the stash... thinking I'd be back around there again. Damn if I couldn't find the guys booth again
ya' know what they say.. "those that hesitate... "
Old Dec 27, 2004 | 10:54 PM
jeaux's Avatar
jeaux
What small piece are ya'll talking about?
Old Jan 3, 2005 | 01:50 AM
carl a's Avatar
carl a
mike , why not dye everything to match, if you like the darker oxblood. then dye the ones that appear lighter to match, some of mine seemed lighter than others, so i went over everthing and now they all match up---some of the pieces that seemed lighter were the parking brake console,,windshield pillar post trim-------
Old Jan 3, 2005 | 11:07 AM
Mike Mercury
Carl, I actually have already started that process - on a few select pieces. My wife doesn't like a bright red interior , and oxblood is the perfect non-black interior color for a C3 IMO.
The door panels are borderline on needing replaced. So I am holding up on painting them.
I REALLY like the pic of your interior !!!
Old Jan 3, 2005 | 12:07 PM
Tom73's Avatar
Tom73
Let me jump in here a bit. Looks as if everyone has said most of this but let me recap. In '73 you could get the deluxe interior only in Black or Saddle. With the deluxe interior you got leather seat covers, cut-pile carpet, carpet on the bottom of the doors, and woodgrain inserts on the doors. Since yours is a red you should not have any of this.
The standard interior would have "comfort-weave" seat covers, chrome bar across upper part of seat where the shoulder belt would come thorugh, loop carpet, and no extra trim of the doors. So it looks as if the door panels are correct but the seat covers and carpet are wrong.
Sorry but cannot comment on the correct red colors. But check out The '73 Sport as I have the color samples posted there.
tom...
To Interior identification with 1973
