Tool Question
Old Dec 28, 2004 | 07:26 PM
MKearney's Avatar
MKearney
Default Tool Question
When my engine was rebuilt the shop screwed some plugs where a sending unit goes. Socket extensions don't fit. Does anyone know what the name of the tool is to remove these plugs.
Old Dec 28, 2004 | 07:29 PM
CA-Legal-Vette's Avatar
CA-Legal-Vette
Which sender and where?
Old Dec 28, 2004 | 07:31 PM
CGGorman's Avatar
CGGorman
It's probably square-drive. Best (cheapest) solution I've found is to get a short length of square keystock from the hardware store that fits the hole in the plug. I had a Jeep that used an odd-size square drive plug in the transfer case. Had to fabricate my own tool for that one...
Old Dec 28, 2004 | 07:33 PM
OkeeGuy's Avatar
OkeeGuy
if the shape is an octagon (8 sides) like the head of a bolt and you dont have the proper tool...
then heres what you can do...
find a bolt that fits in the hole and run 2 nuts onto the bolt and tighten them together so that the "flats" match up...
insert the bolt head into the hole and use a wrench (or socket) on the 2 nuts to turn it out...
works great!
To Tool Question
